Results 1 to 11 of 11
Plumbing & Plumbers Forum - Worcester v Grant v firebird v warmflow
Like Tree3Likes
  • 1 Post By Last Plumber
  • 1 Post By Best
  • 1 Post By SimonG
Discuss Worcester v Grant v firebird v warmflow at UK Plumbers Forums; Hi guys, im after some info on the most common make of oilr boiler u all install. The majority of boilers ive imstalled are worcester, ive always thought grants and ...
    Feb 2012
    39
    Default Worcester v Grant v firebird v warmflow
    Hi guys,
    im after some info on the most common make of oilr boiler u all install. The majority of boilers ive imstalled are worcester, ive always thought grants and some firbirds are a pain in the a@@ to service, where as the worcesters are fairly straight forward. We fitted a couple if warmflos recently and found them to be a bit of a faff tbh, i know their a fair chunk cheaper than the worcester but there was what seemed like a lot of extra work to assemble them! What are your opinions on the range of makes available?
    Last Plumber's Avatar
    Aug 2016
    Lancashire
    1,589
    Default Re: Worcester v Grant v firebird v warmflow
    My opinion on Worcester after sales service is very poor. Sorry that's about the only comment I can think off right this minute.
    Do potterton not still make an oil boiler, I haven't seen one in a few years and I don't install that many. I'm mainly breakdown and service when it comes to oil.
    SimonG likes this.
    Jan 2016
    Near Brecon
    290
    not fussed one way or another.. all oil boilers are a PITA
    N.Ireland, United Kingdom
    7,114
    Grant oil boilers everytime! (I don't like any combi oil though) Can't understand why you would think Grant boilers are hard to service? One door gets you into the two heat exchangers - and usually the door seals last.
    Last Plumber likes this.
    SimonG's Avatar
    16,195
    Warmflow for me.
    Quality of install is where longevity will come from. Too many pee poor installations with no addiional expansion or even mi's not folowed.
    7,114
    Quote Originally Posted by SimonG View Post
    Warmflow for me.
    Must admit I find Warmflow HE boilers fairly easy to service also, but they do have a couple of extra tasks I dislike. Firstly the secondary exchanger has a door you have to remove, then a rubber seal that needs replacing. Then there is the boiler baffles, which have to be properly staggered which is a pain and I bet few bother. Efficiency, even by Warmflows MIs is not just as good as Grant Vortex. Grant baffles are often too tight though and need a bit of careful grinding on some.
    The Warmflow combi is bother and I avoid them, but same with any oil combi.
  7. The Following User Says Thank You to Best For This Useful Post:
    SimonG's Avatar
    16,195
    Wait till you see a HEE Warmflow combi. Done away with one of the pumps and a massive diverter in there now.
    Things on a warmflow combi I don't like :-
    The flexi hose to expansion vessel, gets blocked far too easy.
    Low pressure sensor and pressure gauge seperated by the flexi hose.
    The wiring center. Need hands like a 2 year old to get in. Use wago's now tho.
    Best likes this.
    7,114
    Yes, the flexi between vessel & boiler on Warmflow combi is trouble.
    Also the washers around exchanger passing water plus the usual auto vents
    Feb 2012
    39
    Quote Originally Posted by Best View Post
    On almost every one i do the seals need replacing, its one of my peevs with grant, the snorkles cam be a pita and seem to be an afterthought!
    7,114
    Quote Originally Posted by tridimnaw View Post
    The cord seal on Grants? I find they are okay if I am careful removing the door not to tear them. The seal does get a bit tatty and some sulphur on it, must admit, but as long as it is still going to do its job sealing the gases in, then no problem.
    Jan 2008
    North Yorkshire
    4,778
    I dont like Warmflow boilers at all, I think the build quality leaves a lot to be desired, however they are of course a budget model. Grant every time. The newer Worcesters are a pain in the backside to service.
    On the other question re Potterton, their oil boiler was the "Statesman", however this is no longer made since the company became part of Baxi.
  1. Exchanging warmflow 90 for grant vortex
    By chris2006 in forum Oil and Solid Fuel Forum
    Last Post: 10-10-2015, 03:49 PM
  2. Worcester or Warmflow ?
    By timbo_1975 in forum Central Heating Forum
    Last Post: 24-11-2012, 06:10 PM
  3. Grant vtx eco 2635 v warmflow u120he
    By PaulDibden in forum Oil and Solid Fuel Forum
    Last Post: 06-10-2012, 06:20 PM
  4. Grant or Worcester? Help!
    By fishingscotland in forum Central Heating Forum
    Last Post: 09-06-2010, 07:46 PM
  5. Grant boilers v's Worcester
    By phanney in forum Central Heating Forum
    Last Post: 13-01-2008, 07:21 PM
firebird or worcester
