Results 1 to 6 of 6
Plumbing & Plumbers Forum - wood burner boiler
wood burner boiler
Discuss wood burner boiler at UK Plumbers Forums; sitting looking at weather overnight temperature drops and thought - what is the equivalent to a frost thermostat protection on a wood burner boiler. Clearly its damped down over night ...
    May 2014
    Default wood burner boiler
    sitting looking at weather overnight temperature drops and thought - what is the equivalent to a frost thermostat protection on a wood burner boiler. Clearly its damped down over night or even let go out til next day but what stops any sudden drop in temperature affecting a place in any part of the CH cct i.e radiator in a colder than average room. All pipe lagging etc is up to standard but then new houses with combi boilers have frost protection so ......?.
    deg
    deg is offline
    Oct 2008
    31
    Default Re: wood burner boiler
    Would a standard frost stat fitted outside to bring your pump on, just to circulate the water on cold night do the job?
    Mar 2013
    1,484
    Sentinol X500 inhibitor and antifreeze should address your concerns. Unless wood burner has electronic draft control and automatic fuel feed, other than frost stat on circulating pump as suggested above, your options are limited.
    May 2014
    Quote Originally Posted by deg View Post
    Thanks deg
    thats exactly what i was thinking but didnt know if that was a tried and tested method. on the other hand as mentioned apart from anti freeze which i am not keen on there are not a lot of options. Running water less likely to freeze I would say!
    May 2014
    Quote Originally Posted by joni os View Post
    thanks Joni os
    thinking about it I might give both a go as you never know, pump might fail when you are snoring away at night so belt and braces!
    N.Ireland, United Kingdom
    7,109
    Unless you have pipes run in the attic or exposed to outside, then you will not have pipes or radiators freezing. Unless of course the rooms or entire house is left for days without some heat.
    Only times I have seen pipes inside a house freezing is where there was no heat, usually in unoccupied buildings. So a sudden subzero nights weather will not freeze a room in a heated home
  1. Wood Burner with back boiler
    By martin4036 in forum Oil and Solid Fuel Forum
    Last Post: 02-06-2012, 01:39 AM
  2. Wood Burner with back boiler
    By martin4036 in forum Central Heating Forum
    Last Post: 31-12-2011, 12:06 AM
  3. wood burner back boiler
    By carljon in forum Central Heating Forum
    Last Post: 30-08-2011, 03:38 PM
  4. combining wood burner and boiler
    By joe plumber in forum Renewable Energy
    Last Post: 08-12-2010, 08:29 PM
  5. Wood Burner leaking gravity boiler
    By hjones in forum Plumbing Forum
    Last Post: 04-12-2010, 03:57 PM
