Results 1 to 8 of 8
Plumbing & Plumbers Forum - Danfoss MSLC032 bleeding
Like Tree5Likes
  • 1 Post By SimonG
  • 2 Post By SimonG
  • 2 Post By croppie
Discuss Danfoss MSLC032 bleeding at UK Plumbers Forums; Hi! I need to bleed an airlock out of the ancient oil-boiler here - previous tenant ran it dry. Can anyone tell me which is the bleed valve? I'm thinking ...
    Nov 2016
    Default Danfoss MSLC032 bleeding
    Hi!
    I need to bleed an airlock out of the ancient oil-boiler here - previous tenant ran it dry. Can anyone tell me which is the bleed valve? I'm thinking the bottom one with the nut but the upper allen type one seems to have had more action based on the amount of rust. Pump is Danfoss MSLC032. Hope the picture came through. Sorry about the quality - it's pitch black down there.
    Thanks!
    SimonG's Avatar
    16,113
    Default Re: Danfoss MSLC032 bleeding
    Get an engineer to sort it and show you what's what at the same time. Dont play as you may change the oil pressure.
    croppie likes this.
    Forum Thug
    croppie's Avatar
    23,821
    ^^^^^^ seen it done soooooooooo many times.
    Croppie
    (By the way, I'm commercial!)
    N.Ireland, United Kingdom
    6,991
    Great quality pump, but must be near its end. That oil pump has to be 30 + years old. If you touch the wrong part you will destroy the old pump as well as changing the oil pressure.
    Nov 2016
    Thanks for the responses. Do any of you know the answer to the question of which is the bleed valve on this pump though? In case I want to foolishly disregard your good advice? I get that touching the wrong part might be a problem, hence the question of which is the right part to touch.
    SimonG's Avatar
    16,113
    For you. None of them.
    ShaunCorbs and Best like this.
    6,991
    5 days and still not sorted. Obviously that boiler is in need of an oil engineer to look at it, overhaul and service it or more likely to recommend it to be replaced.
    Forum Thug
    croppie's Avatar
    23,821
    And I think we'll close it there.
    Best and tn245 like this.
    Croppie
  1. Bleeding customers!!
    By Fallon1982 in forum Plumbing Forum
    Last Post: 15-08-2015, 12:56 PM
  2. Radiators need bleeding every day !!
    By paul.binding.52 in forum Central Heating Forum
    Last Post: 02-02-2014, 08:40 AM
  3. Bleeding system, 2 rads not bleeding
    By Taffytim in forum Central Heating Forum
    Last Post: 05-12-2013, 07:23 PM
  4. Always bleeding one rad
    By lordyjordy111 in forum Gas Safe Register Forum - Public Forum
    Last Post: 13-11-2012, 06:36 PM
  5. bleeding air.
    By Johnx14 in forum Plumbing Forum
    Last Post: 12-10-2010, 01:56 PM
