Page 1 of 5 1234 ... LastLast
Results 1 to 12 of 52
Plumbing & Plumbers Forum - Sooted up boiler and other tips
Like Tree33Likes
Discuss Sooted up boiler and other tips at UK Plumbers Forums; Just a reminder to folks that when you come across a sooted up boiler (usually where a conventional flue is blocked, a balanced flue gasket breaks down (ex the early ...
    Jan 2008
    North Yorkshire
    4,775
    Default Sooted up boiler and other tips
    Just a reminder to folks that when you come across a sooted up boiler (usually where a conventional flue is blocked, a balanced flue gasket breaks down (ex the early Trianco square balanced flues) or a pump wears out), after you have de-sooted the boiler and fixed the problem, it will take several hours for the loose soot to burn off and give you a reliable CO reading on your analyser.
    Use your smoke pump to get the smoke down, leave the boiler running and come back in a couple of hours to set up with the analyser.
    Member Bunker's Avatar
    Oct 2012
    Newbury, Berkshire
    1,125
    Default re: Sooted up boiler and other tips
    I'd add to that, leave the boiler running over aired or lower jetted for a few days if bad. Smoke tests early will show yellow which is your unburnt soot.
    stani, croppie and Best like this.
    OFTEC C10240 The Friendly Oil Boiler Service.
    Installation, servicing, commissioning and repairs.
    G3 Unvented.
    Forum Thug
    croppie's Avatar
    23,718
    Great tips! Thank you. Any other tips or tricks please add to this thread
    Gonna sticky this one.
    Croppie
    (By the way, I'm commercial!)
    Jan 2011
    Newton Abbot
    893
    Better still chuck in a soot stick or spray with dualx to get rid of it all
    Oct 2012
    Newbury, Berkshire
    1,125
    Top tip:
    Black nozzles/ stems often mean late ignition. This doesnt mean the electrodes come on late, it means the oil actually 'catches fire' after alot of oil has already been sprayed in. This causes a whump on start up which, as well as being noisy, blows oil back down the blast tube.
    The best way to check is to take the burner out, remove the coil or the coil connector, and fire it up. A bit frightening at first but with the coil off it wont actually fire (although handle it as if it will, just to be safe). You can then watch the ignition arc and where the air takes it - it should be pushed by the air beyond the nozzle and into where the oil spray should be.
    This can be caused by a few things including:
    1. electrodes too close together so not much of an arc - bend apart, being careful if ceramic insulation.
    2. electrodes too far back or forward - adjust to suit
    3. electrodes too close to blast tube or nozzle and the arc not then being blown into the atomised oil - adjust to suit
    The above is not comprehensive so please feel to add to it.
    lame plumber and Killy Bing like this.
    G3 Unvented.
  6. The Following 2 Users Say Thank You to Bunker For This Useful Post:
    Jan 2008
    North Yorkshire
    4,775
    Sooting up can be caused by several problems if it just happens suddenly.
    Blocked flue (birds nest etc)
    Debris on baffles if not serviced for some time
    Blocked air intake or fan (leaves, cat fur, dead mouse etc)
    Faulty nozzle
    oil leaking from behind nozzle (a few turns of PTFE round the nozzle thread will cure this)
    contaminated fuel
    Failed flue seal between the inlet and flue on a balanced flue. Common fault on the early Eurostars. See here: Trianco leaking balanced flue fault repair
    The part number for these gaskets is Trianco 221647 and you need 2 of them and a bit of silicone grease for assembly.
    Some of the early eurostars don't have the red gasket in which case remove the flue sections and reassemble with high temperature silcone
    Oct 2012
    Newbury, Berkshire
    1,125
    or sticking a wrong nozzle in - I did that recently, lord knows how I picked up the wrong one - .85 instead of a .75.....this is the result over 3 days:
    Attached Thumbnails Attached Thumbnails Sooted up boiler and other tips-img_1332.jpg
    G3 Unvented.
    Roger Welton's Avatar
    Dec 2011
    Somerset
    3,135
    Default Sooted up boiler and other Trick.
    Quote Originally Posted by WHPES View Post
    The nozzle seals on the flat face of the nozzle assembly to the rear of the nozzle, not the threaded section, sometimes get a bit of dirt in the wrong place causing them to drip, if eroded then a replacement nozzle assembly is required.
    Read more: http://www.ukplumbersforums.co.uk/pl...#ixzz2AdEwjWbf
    Jan 2008
    North Yorkshire
    4,775
    If the nozzle assembly mating surfaces get slightly marked or deformed you can get a leak. A lot of the problems tend to be on old and obsolete burners where the nozzle has been taken out many times and as such spare parts are often unavailable.
    Oct 2012
    Newbury, Berkshire
    1,125
    Default Re: Sooted up boiler and other tips
    Perhaps we should have a section where, when taking out an old boiler, we can announce it and if anyone has a problematic version, they can ask for parts from it.
    steveb and croppie like this.
    G3 Unvented.
    Dec 2011
    Somerset
    3,135
    My garage does look like a burner graveyard at times, tend to keep a couple of old burners around for emergency use.
  13. #12
    SimonG's Avatar
    16,035
    I always have a standby ready to go.
  1. boiler breakdown tips from training centre
    By lordyjordy111 in forum Gas Safe Register Forum - Public Forum
    Last Post: 27-05-2013, 10:49 PM
  2. boiler breakdown tips from training centre
    By lordyjordy111 in forum Central Heating Forum
    Last Post: 26-05-2013, 10:46 PM
  3. Tips on removing a back boiler
    By gregg1908 in forum Gas Safe Register Forum - Public Forum
    Last Post: 25-08-2011, 08:01 PM
  4. Baxi 552 BBU - sooted up
    By maintain2let in forum Central Heating Forum
    Last Post: 21-02-2011, 01:01 PM
boiler sooting up
oil boiler sooting up
oil boiler keeps sooting upback boiler sooting upDe sooting of boiler
