Results 1 to 2 of 2
Plumbing & Plumbers Forum - removing neutralizer
Discuss removing neutralizer in the Oil and Solid Fuel Forum at Plumbers Forums; layout1.jpg This is the present layout. The solid fuel fire is been removed therefore the neutralizer is also been removed to make more space in cupboard. There are 2 pumps ...-
02-07-2012 #1Steady Plumbing Forum Contributor
- Mar 2010
- s****horpe
- 129
- 8
- Thanked 5 Times in 5 Posts
layout1.jpgThis is the present layout. The solid fuel fire is been removed therefore the neutralizer is also been removed to make more space in cupboard. There are 2 pumps in situ, one for boiler flow ? the other im not sure about, I think the pump with the motorised valave must be to pump the water when the solid fuel fire is in use ? However one will be removed and the system will be made to a standard Y -plan with a mid diverter valve. My question is should the F&E pipes be moved to before the pump, as surely if kept on the coil in / out pipes this will cause them to be under positive pressure and blow water back up to the tank ?? there is enough room to move them and put them together in the flow pipe before the pump ?? any advise
03-07-2012 #2New to Plumbing Forum
- Jul 2012
Re:Industrial paper shredder
I have the same question but i can't solve it ?
Looking for someone to install neutralizer
By SoxandMax in forum I'm looking for a Plumber or Gas EngineerReplies: 1Last Post: 18-12-2011, 10:00 PM -
dunsley baker neutralizer link up system
By peach plumbing in forum Plumbing ForumReplies: 19Last Post: 30-04-2011, 01:57 PM -
Removing silicone
By wheeto in forum Plumbing ForumReplies: 0Last Post: 24-11-2010, 10:32 AM -
removing whb and rad
By adrianfs1 in forum Plumbing ForumReplies: 6Last Post: 15-01-2010, 09:24 PM -
Removing Old Olives
By pt44 in forum Plumbing ToolsReplies: 26Last Post: 31-05-2009, 05:52 PM
There's no stopping this water!
4 Minutes Ago in Plumbing Forum
