Results 1 to 12 of 13
Plumbing & Plumbers Forum - Can anybody install a coal-fired roomheater?
Discuss Can anybody install a coal-fired roomheater? in the Oil and Solid Fuel Forum at Plumbers Forums; Hi can anybody install/commission/remove a coal fired roomheater or a coal burning appliance or do you have to have HETAS registration or something? I am gas safe registered but its ...-
10-06-2012 #1Plumbers Arms member
- Sep 2011
- Wales
- 232
- 16
- Thanked 2 Times in 2 Posts
Hi
can anybody install/commission/remove a coal fired roomheater or a coal burning appliance or do you have to have HETAS registration or something? I am gas safe registered but its a different kettle of fish solid fuel isnt it?
regards
Its not a leak till it comes out of the letterbox
10-06-2012 #2UK Plumbersforums Trusted Advisor.
- Apr 2009
- Tunbridge Wells
- 5,167
- 531
- Thanked 430 Times in 365 Posts
Re: Can anybody install a coal-fired roomheater?
Don't know the answer to that question. I thought you had to be Hetas Registered.....I don't know though. Probably not.
Gone fishing!!
11-06-2012 #3UK Plumbersforums Trusted Advisor.
- Apr 2010
- Scotland
- 9,546
- 281
- Thanked 1,206 Times in 1,073 Posts
If you are in England you need to be Hetas registered to fit one but like everything else, having a ticket doesn't mean they particularly know what they are doing.
To take one out you just need a 4lb hammer and a spare 2hrs
11-06-2012 #4UK Plumbersforums Trusted Advisor.
- Dec 2010
- WestMidlands
- 6,042
- 125
- Thanked 593 Times in 565 Posts
you do not have to be hetas registered to install solid fuel appliances but if your not hetas registered then you will have to pay local building control to sign off the installation. This can be between £150 to £250 per visit. The installation needs to comply with building regs with special attention to parts G,J,L.
btw im commercial, NOT.
13-06-2012 #5Steady Plumbing Forum Contributor
- Mar 2010
- s****horpe
- 131
- 8
- Thanked 5 Times in 5 Posts
Hi yes, as stated above by AWheating, the HETAS is not a must have to install, if you are considered competant. My neighbour asked me to install one for them, but like i told them, I could install it but they would need it signing off by for buildings regs and the flu plating and sealing etc. As stated above another expense, which makes it more expensive than just getting someone with the ticket to do the work and sign it off.
13-06-2012 #6
You can be on a number of CPS (competent persons schemes) to sign off your own solid fuel, APHC, NICEIC, NAPIT etc all do them, same with oil.
19-06-2012 #7Plumbers Arms member
- Dec 2009
- 869
- 11
- Thanked 81 Times in 77 Posts
01-07-2012 #8UK Plumbersforums Trusted Advisor.
- Jan 2008
- North Yorkshire
- 4,155
It's like anything else - there will have to be a high profile media case where a family dies due to an incorrectly fitted soild fuel appliance before it will be mandatory and enforced for HETAS registration for an installer.
03-08-2012 #9Plumbers Arms member
- May 2010
- 581
- 10
- Thanked 30 Times in 30 Posts
Hi guys do you have to be HETAS to service clean out coal boilers ?? Trianco ect
03-08-2012 #10UK Plumbersforums Trusted Advisor.
- Apr 2010
- Scotland
- 9,546
- 281
No. It can be done (and usually is) by the householder.
04-08-2012 #11Top Plumbing Forum Contributor
- Feb 2011
- 701
- Thanked 77 Times in 74 Posts
If you class servicing as changing door seals, replacing broken parts and checking function of controls etc, then to carry out work for money for other people you would need to prove competence and being registered in a formal scheme would be the easiest way to do that.
04-08-2012 #12Plumbers Arms member
- Dec 2009
- 869
- 11
What's coming down the road is the German system where all solid fuel appliances with a rating above 15Kw must be serviced Twice a year by what they call the Chimney Sweep, he / she is no ordinary chimney sweep they must carry out a full service (seals etc) fire up the appliance and use a FGA to certify the emissions Nox being the main target, flue draught etc.
That is why when you look at the German market (and others) boilers tend to be just below 15Kw output and anything over that are gasifiers.
Too many people who buy solid fuel stoves and boilers treat them as furnaces, not unusual to hear people saying the plastic bottles (milk cartons, coke bottles etc) are great for starting the fire, imagine what POC's off those appliances are?
coal fire
By desrob in forum Gas Safe Register Forum - Public ForumReplies: 12Last Post: 14-05-2012, 08:56 PM -
Retrofit wood-fired hot water into new, oil-fired CH and HW system?
By NorfolkBumpkin in forum Renewable EnergyReplies: 18Last Post: 17-11-2011, 08:42 PM -
coal chute
By BOD in forum Gas Safe Register Forum - Public ForumReplies: 9Last Post: 19-06-2011, 06:31 PM -
Coal fire dilema
By Joey Poey in forum Central Heating ForumReplies: 10Last Post: 02-01-2011, 08:52 AM -
Parkray Cumbria Inset Roomheater
By timkenyon in forum Gas Safe Register Forum - Public ForumReplies: 7Last Post: 03-04-2010, 03:43 PM
1Likes
Holidays
