Results 1 to 8 of 8
Plumbing & Plumbers Forum - Drilling FOUR holes into bath to fit Hansgrohe taps with porsadrill at 365-drills
Like Tree4Likes
  • 1 Post By 365drills
  • 2 Post By rpm
Discuss Drilling FOUR holes into bath to fit Hansgrohe taps with porsadrill at 365-drills at UK Plumbers Forums; The guys at Hansgrohe have made life great for clients but difficult for installers. There is now a bath mounted tap unit for sale that will need four precision holes ...
    ** UKPF Sponsor **
    365drills's Avatar
    Sep 2008
    Hoddesdon
    492
    Default Drilling FOUR holes into bath to fit Hansgrohe taps with porsadrill at 365-drills
    The guys at Hansgrohe have made life great for clients but difficult for installers. There is now a bath mounted tap unit for sale that will need four precision holes drilled to install correctly Here is an image of the taps. Note the layout and style can vary: But the base plate is the same !
    The important thing is that you are going to need six drills to install the holes for this unit.
    They are 2 x 30mm 1 x 35mm 1 x 50mm steel cutting drills plus 2 x 35mm 1 x 40mm 1 x 55mm diamond cores
    And plan on about 2 hours of work plus any travel time if you are paying to have the holes drilled.
    Lets make a start...
    First we used the chrome plate to help mark out the bath to drill the holes. The client wanted the TAP centered to the waste. Not the plate centered to the bath. So the holes we will drill are offset.
    Its VERY important to choose a bath capable of holding the 75mm plate. Its quite deep. If you have a shallow tap area the plate will stick out. Choose your bath wisely !
    Plate removed (and stored SAFELY) we mark the final position of every hole. We use indelible pental marker pens which do come off with baby wipes. Trust me a lot of holes have been drilled. This bath is a Kaldewei puro 687.
    We marked out the bath in critical detail. 110mm per hole. We then used diamond to grind down the enamel and expose the metal to dead center. This is where we put our pilot drills. We drill out all four pilot holes.
    You can see all four pilot holes drilled in the bath. The baby wipes have been used to remove all markings. It is better to work in a clean environment when drilling holes into baths,
    To get the markings you are better off to have part number 13444180 or 39449000 to guide you
    This is part that you need. as you can see there is some flex in the fixings but not the top mount
    The manual is quite details but you do need to read all the instructions.
    Its no good having this top part. There are no install instructions for this unit in this box.
    Make sure you reseal all the Hansgrohe boxes there are too many things to lose
    The holes should match the template above
    I believe we have drilled in all the right places. Hansgrohe fittings are difficult but if you follow the instructions
    Painted in enamel paint to prevent rust
    Looking great. Takes 24 hours for paint to harden. Do not install until next day
    Did this project help you drill your own bath or educate you as to what you need to do? At 365drills we provide a bath drilling service for £200+VAT per day. Or we supply the full set of drills and toolpack (paint & brushes etc) to do this job for £49.99. If you need help call us. We can come and do it. Or we can provide all the equipment you need. Call us on 01992 410636 for more info. Or email [email protected] : We are experts and drilling holes in ANY bath.
  2. The Following 2 Users Say Thank You to 365drills For This Useful Post:
  3. #2
    AlexGas's Avatar
    Sunny Southampton
    2,884
    Default Re: Drilling FOUR holes into bath to fit Hansgrohe taps with porsadrill at 365-drills
    Got your Porsadrill set - 7 diamond drills. Great kit!
    Make it happen!
  4. The Following User Says Thank You to AlexGas For This Useful Post:
  5. #3
    ** UKPF Sponsor **
    365drills's Avatar
    Sep 2008
    Hoddesdon
    492
    Nice one!
    Dont forget we do the box sets of diamond cores as well !
  6. #4
    Riley's Avatar
    Sarf Coast
    6,468
    Nice job how blooming expensive is that shower set
  7. #5
    ** UKPF Sponsor **
    365drills's Avatar
    Sep 2008
    Hoddesdon
    492
    Yes exactly. That shower set (hot tap : cold tap : spout and shower) is £1700 quid
    ANd the bath £600 quid!
    A lot of £££££ for a small item.
  8. #6
    rpm
    rpm is online now
    Member rpm's Avatar
    Wherever I lay my hat
    7,958
    How do you measure 20 Nm when using a spanner?
    Riley and 365drills like this.
  9. #7
  10. #8
    rpm
    rpm is online now
    Member rpm's Avatar
    7,958
    Guess one way is a Crows foot and a torque wrench.
  1. TOOLFAIR 2013: See 365-Drills exhibition PORSADRILL tile drills cutting holes bits
    By 365drills in forum Links, Forum Updates, News and Site Suggestions
    Last Post: 13-08-2013, 01:18 PM
  2. Tiles-Ahead WALES stockists of PORSADRILL tile drilling holes in very hard porcelain
    Last Post: 15-07-2013, 12:59 PM
  3. Now offering TWO displays for retailers of diamond core holes tile drills PORSADRILL
    Last Post: 30-05-2013, 12:06 PM
  4. WATFORD: New retailer of PORSADRILL diamond core tile drills for holes in porcelain t
    Last Post: 21-05-2013, 06:46 PM
  5. Drilling holes in bath for taps
    By Curlyworld in forum Plumbing Courses
    Last Post: 08-06-2009, 06:22 PM
