Results 1 to 14 of 14
Plumbing & Plumbers Forum - how to garuntee work
Discuss how to garuntee work in the Insurance for Plumbers at Plumbers Forums; Hello guys, im new to the plumbers forum and i was wondering if any of you chaps could give me some advice on how to garuntee work, some guys will ...-
18-10-2010 #1New to Plumbing Forum
- Oct 2010
- 6
Hello guys, im new to the plumbers forum and i was wondering if any of you chaps could give me some advice on how to garuntee work, some guys will give a 5 year garuntee on their work. how do you back this up? i know that roofers for example have insurance to back up their work. is it a similar case with plumbing? do any of you guys have insurance to back up your work garuntee?
thanks any advice would be appreciated.
18-10-2010 #2UK Plumbersforums Trusted Advisor.
- Apr 2008
- South Shropshire
- 6,039
- 501
- Thanked 676 Times in 610 Posts
Re: how to garuntee work
I just return (free of charge of course) if they're not happy.
Apart from (when I was new) a radiator falling off a wall (BIG EMBARRASSING OOPS!!!
) and the odd small leak, it's never been an issue.
Just be conscientious and careful first time round and don't tackle anything more than you're comfortable with.
19-10-2010 #3Plumbers Arms member
- Jan 2008
- leeds
- 718
- 16
- Thanked 13 Times in 13 Posts
I will only guarantee anything if my parts are used which is three months, I have never had a problem with this
20-10-2010 #4Steady Plumbing Forum Contributor
- Aug 2010
- 155
- 21
- Thanked 9 Times in 9 Posts
I offer 2 years on all bathroom refurbs. As above if there is a problem just go back and put it right.
23-10-2010 #5Steady Plumbing Forum Contributor
- Jun 2009
- 188
so there is no national standard to say you have to guarantee your work for x amount of time then?
24-10-2010 #6Steady Plumbing Forum Contributor
- Aug 2010
- 155
- 21
Yes read 'Supply of goods and services Act'
It may suprise you!
29-10-2010 #7Top Plumbing Forum Contributor
- Aug 2010
- 326
- 18
- Thanked 13 Times in 12 Posts
garauntee for 5 years then tell them to p off when they call you
Last edited by REDSAW; 29-10-2010 at 11:22 PM. Reason: swear again and you will be banned
29-10-2010 #8Top Plumbing Forum Contributor
- Aug 2010
- 326
- 18
joking bye the way
31-10-2010 #9Plumbers Arms member
- Jul 2008
- 104
- Thanked 4 Times in 4 Posts
In my terms and conditions I point out I will guarantee my workmanship for 12 months, if I've supplied the parts I will go back and replace foc, if they've supplied the parts all bets are off
31-10-2010 #10Steady Plumbing Forum Contributor
- Aug 2010
- 155
- 21
Mark, if the parts you fit fail do you seek the cost of replacing from the maufacturer?
02-11-2010 #11UK Plumbersforums Trusted Advisor.
- Jan 2008
- North Yorkshire
- 4,150
If any parts I fit fail, I give the manufacturers hell. Actually the only things I have had fail have been four Triton electric showers which all but one failed just after their warranties had run out. Hard luck from Triton, tried to sell me expensive parts. I'm NEVER buying Triton stuff again. Bristan on the other hand sent a replacement part free of charge even though the item was out of warranty. Tops!
02-11-2010 #12Steady Plumbing Forum Contributor
- Aug 2010
- 155
- 21
Aqualisa and Mira are pretty good at giving the spares out too. I have had new cartridges from both FOC outside of warranties.
05-01-2011 #13
Yeah i will give 12 months on my labour and my parts. And yeah i find bristan very good on giving spares free of charge so i tend to fit alot of their taps.
05-01-2011 #14Plumbers Arms member
- May 2008
- 700
- Thanked 20 Times in 20 Posts
i fitted a new outside tap today when i turned it on to test no water........ so i isolated took it off and checked water supply all was good i then checked the none return valve in the tap and it was sticking a bit so i freed it off. put tap back on and still nothing took it off again and the had put a none return valve in the outlet end of the tap aswell. no water wasever going to pass that tap.
gas safe number and work outside of work!!
By beesley121 in forum Gas Safe Register Forum - Public ForumReplies: 21Last Post: 28-01-2013, 10:23 PM -
looking for work/experience will work for low wage
By plumb1039 in forum Plumbing ForumReplies: 1Last Post: 13-07-2010, 04:49 PM -
By plumb1039 in forum Looking for work.Replies: 0Last Post: 12-07-2010, 10:41 PM -
Plumber's/Gas Engineer's Mate work wanted (will work for free)
By martin29 in forum Gas Safe Register Forum - Public ForumReplies: 0Last Post: 09-07-2010, 03:25 PM -
will this work
By mjice in forum Plumbing ForumReplies: 0Last Post: 06-01-2009, 06:21 PM
HALL of SHAME PHOTo`s
2 Minutes Ago in General Off-Topic Chat
