Results 1 to 2 of 2
Plumbing & Plumbers Forum - Baxi Eco80 wont fire CH unless i turn on DHW tap
Discuss Baxi Eco80 wont fire CH unless i turn on DHW tap at UK Plumbers Forums; I have an interesting problem with Baxi Eco80 boiler which i inherited when i moved into my flat a few month ago. At first i thought it was the thermostat ...
    Dec 2016
    Default Baxi Eco80 wont fire CH unless i turn on DHW tap
    At first i thought it was the thermostat so i recently replaced it with a 3rd Gen Nest. However its evidently not the thermostat.
    Problem occurs when the boiler has been idle for a long time i.e both CH and DHW have not been running.
    When the thermostat kicks in, i can hear the pump running but no flame ignition. The problem seems to be resolved only by turning on a hot water tap after which the flame ignition sequence seems to work just fine and the CH system fires up.
    Once the system is running it seems to be able turn off and on (as demanded by the thermostat) however if left off for too long the same problem occurs.
    I have checked the system pressure is set correctly to 1.5 barg,
    Ay idea what the problem could be?
    location GU15 postcode
    Responsible Moderator...
    APPlumbing's Avatar
    Locks Heath fareham
    13,358
    Default Re: Baxi Eco80 wont fire CH unless i turn on DHW tap
    If interested please pm the op directly.
    I have an unfortunate problem. I should stand upwind if I were you!
  1. Baxi Eco80 wont fire CH unless i turn on DHW tap
    By rizz077 in forum Central Heating Forum
    Last Post: 15-12-2016, 09:35 PM
  2. Baxi eco80 no hot water
    By andyRN in forum Plumbing Forum
    Last Post: 13-01-2012, 11:56 PM
  3. baxi bermuda 57/4e pilot on but wont fire up
    By magical in forum Central Heating Forum
    Last Post: 05-01-2012, 11:37 AM
  4. Baxi system 35/60 boiler wont fire
    By MV07SMV in forum Central Heating Forum
    Last Post: 22-10-2011, 10:24 PM
