Plumbing & Plumbers Forum - Norwich - Heat exchanger plate
Discuss Norwich - Heat exchanger plate at UK Plumbers Forums; Hi there, In Norwich area Ideal mini c28 Can anyone give me estimate on how much to clean a heat exchanger plate? I'm not sure how it would work as ...
    Feb 2016
    17
    Default Norwich - Heat exchanger plate
    Hi there,
    In Norwich area
    Ideal mini c28
    Can anyone give me estimate on how much to clean a heat exchanger plate? I'm not sure how it would work as I read that you should soak it in cleaner for 24h so not sure how it would work calling someone out? Or is it easier/cheaper to replace it?
    Many thanks
    Oct 2013
    Suffolk
    280
    Default Re: Norwich - Heat exchanger plate
    We do try and clean them although sometimes they are too far gone, I tend to try and bring a spare with me so if it's not worth cleaning we can put the new one in straight away saves two visits.
    Otherwise we can remove one morning and replace the next although not ideal this time of year!
    We are also based in Norwich
    01603 665163 Premier Heating
    Forum Thug
    croppie's Avatar
    23,814
    If this job interests you please PM the op direct.
    Croppie
    (By the way, I'm commercial!)
  1. Plate heat exchanger
    By buckley plumb in forum Central Heating Forum
    Last Post: 09-04-2016, 09:41 PM
  2. Replies: 20
    Last Post: 08-07-2014, 10:58 PM
  3. 30 CDI Plate Heat Exchanger
    By ShaunDB in forum Central Heating Forum
    Last Post: 09-01-2014, 07:10 PM
  4. Plate heat exchanger
    By Bennett in forum Plumbing Forum
    Last Post: 18-05-2012, 05:41 AM
