Results 1 to 2 of 2
Plumbing & Plumbers Forum - Supply Run and Connect Gas Hob - Windsor
Discuss Supply Run and Connect Gas Hob - Windsor in the I'm looking for a Plumber or Gas Engineer at Plumbers Forums; Hello guys, Been a long time but thought I’d try looking on another of Dan's forums for a Gas safe engineer. We are doing a job in Windsor way out ...-
16-05-2012 #1New to Plumbing Forum
- Dec 2009
- 3
- Thanked 1 Time in 1 Post
Hello guys,
We are doing a job in Windsor way out of our normal area and need a gas safe engineer to run a supply of approx 6-7m from the nearest and only appliance, the boiler (which is currently supplied in 22mm) to a new 6 ring hob.
Supply may need to be run on the exterior of the property. There is an easily accessible crawl space under the property but may not be well ventilated enough to allow the pipes to be run under. Either way it's a nice straight forward job with easy access, I know you hear that all the time!! But it really is!! Only spanner in the works is if for some reason you think it needs a new supply from the meter in 28 to service boiler and hob. (Current run from meter to boiler in 22mm is approx 6-7 meters)
We are more than happy to run the pipe work ourselves and wait for final connections from yourself. Whichever way you want to work really. Depends on your work load.
Job would need to be done within the next 2 weeks which is when we leave site.
Anyway if anybody in the Windsor/Slough/Maidenhead area is interested give me a quick PM and I’ll give you a call. Or if one of the mods knows of a trusted plumber in the area give me a quick nudge too.
Cheers all
Rob @ Colour Republic
16-05-2012 #2Moderator
- Nov 2007
- hythe hampshire
- 9,098
- 479
- Thanked 761 Times in 741 Posts
Re: Supply Run and Connect Gas Hob - Windsor
thank you for posting this. if anyone is interested can they contact the op directly thank you.
The Following User Says Thank You to steveb For This Useful Post:
Colour Republic (16-05-2012)
Re-connect gas fire with a couple of NCS's?
By FlameWorx in forum Gas Safe Register Forum - Public ForumReplies: 12Last Post: 23-10-2011, 02:15 PM -
Turned off electric and water supply to boiler, but left the gas supply on!!!
By tommyg01 in forum Central Heating ForumReplies: 5Last Post: 05-09-2011, 07:42 PM -
parkinson Cowan Windsor radiant gas fire
By stani in forum Gas Safe Register Forum - Public ForumReplies: 0Last Post: 12-08-2011, 09:40 PM -
How do i connect this and what do i need
By womble in forum Plumbing ForumReplies: 14Last Post: 18-06-2010, 11:09 AM
1Likes
Relief valve for Unvented Indirect...
2 Hours Ago in Plumbing Forum
