Chatrooms
Wakefield domestic plumber needed -
Go Back   Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK > Plumbing Forums > Plumbing Forum > I Need A Plumber
Notices
Old 20-01-2010   #1 (permalink)
ceilingfish
Info
Default Wakefield domestic plumber needed
Hi chaps,
Firstly my apologies for my absolute lack of knowledge, I am by no means a professional plumber! I do however have what I consider a strange problem.
So I've got this tank in my attic (which I think is called a head tank, but I may be very wrong), and water keeps on running out of it's overflow pipe and dripping down the side of my house. What seems weird to me is that the water in the tank is hot, and it's pouring in from a pipe that appears to run from my boiler.
Surely my boiler shouldn't be sending hot water to this tank, it should be sending it to the hot water tank. Regardless if I close a valve that is on that pipe it slows down the flow to nothing but a trickle, but then I don't have any hot water.
Does anyone fancy taking a look?
Tom
PS PM me for contact details
ceilingfish is offline
Old 20-01-2010   #2 (permalink)
secret squirrel
Info
Default Re: Wakefield domestic plumber needed
How many tanks in your loft? The header tank is the small one.
On the vent pipe that is an open pipe that flows into the tank from the top, this should not have any valves on it, if it does this is wrong and DO NOT turn it off.
secret squirrel is offline
Old 20-01-2010   #3 (permalink)
ceilingfish
Info
squirrel,
There's one tank, and in the airing cupboard below it there's a larger tank.
Last edited by ceilingfish; 20-01-2010 at 10:37 PM. Reason: It's an airing cupboard not an airing tank. muppet.
Old 20-01-2010   #4 (permalink)
secret squirrel
Info
The valve your turning off is the cold feed to the hot water cylinder, so in effect your turning your hot water off.
I think the problem may be with your boiler thermostat, try turning it down to see if it has any effect.
I'd also wait and see if anyone else has any ideas.
Old 24-01-2010   #5 (permalink)
ringw
Info
if its the small tank in the loft it could be it is pumping over which will be a blocked cold feed but would get someone to have a look
ringw is offline
domestic plumber needed jaketwin2 I Need A Plumber 1 2 Weeks Ago 04:37 PM
Secondary expansion vessel needed with new boiler? Rich1974 Central Heating Forum 12 2 Weeks Ago 11:38 PM
Gas certified plumber needed Islington/London londonplumber30 Plumbing Forum 0 02-06-2009 03:18 PM
boiler advice needed for totally non plumber telmand Central Heating Forum 5 20-04-2009 07:14 PM
plumber needed in edinburgh kilty55 Plumbing Forum 1 18-08-2008 10:22 AM
