Page 4 of 4 FirstFirst 1234
Results 37 to 41 of 41
Plumbing & Plumbers Forum - How long does it take to service a boiler?
Like Tree20Likes
Discuss How long does it take to service a boiler? at UK Plumbers Forums; Condensing Worcester boilers require Air/Gas ratios to be checked. in service mode. Both at High/Low levels. The fan pressure has to be checked to make sure the heat exchanger is ...
  1. #37
    Mar 2015
    Default Re: How long does it take to service a boiler?
    Condensing Worcester boilers require Air/Gas ratios to be checked. in service mode. Both at High/Low levels. The fan pressure has to be checked to make sure the heat exchanger is clean. If the readings aren't found to be within the manufacturers required tolerances, then the heat exchanger will have to be cleaned. This would mean the seal connecting to the primary heat exchanger will have to be replaced. etc. Non condensing boilers are easier to service.
  2. #38
    newcastle phill's Avatar
    Jan 2014
    3,729
    Havent read all the posts but takes me approx 1 hour.
    AlexGas likes this.
    Using Tapatalk
  3. #39
    ADMINISTRATOR REDSAW's Avatar
    Jan 2009
    Nottingham
    13,335
    anywhere between 30m and 2 hours, depends what needs doing it could be £10 for the work and £40 to know what needs doing!
    with a combi, you dont touch what dosnt need attention it just needs to be checked that its good.
    i shine a high powered torch into the condense traps and it s like an x-ray. if its clear then i save 10mins fiddling it on and off...
    jtsplumbing and AlexGas like this.
    ¿ʞɹoʍ sɐƃ
  4. #40
    Nov 2016
    24
    Quote Originally Posted by joni os View Post
    Sparky doing Periodic Test, recommended, inspect 10% of sockets. Retest every 6 years.
    Not just that but they write down measurement readings and what they found and give that to you the client.
  5. #41
    Nov 2016
    24
    Quote Originally Posted by AlexGas View Post
    ...don't bother with car MOT or dentist!?
    well, that's why I said it may not be a good idea.
    I don't bother with the dentist myself...
    But to stick to the analogy, MOT would be the gas safety check and car servicing would be the boiler servicing, so stick with the MOT so all is safe and think skip the servicing if all you're going to get is the MOT again.
  1. Long distance from boiler to tap
    By TAKdriver in forum Plumbing Forum
    Last Post: 20-03-2015, 09:55 AM
  2. How long to hang a boiler?
    By that bloke. in forum Central Heating Forum
    Last Post: 29-03-2011, 10:33 AM
  3. Boiler on too long
    By Jilly in forum Plumbing Forum
    Last Post: 25-11-2010, 08:55 PM
  4. How long it takes on average to service an oil fired boiler?
    By OFTEC in forum Oil and Solid Fuel Forum
    Last Post: 23-11-2010, 02:37 PM
  5. How long it takes on average to service an oil fired boiler?
    By OFTEC in forum Central Heating Forum
