Page 2 of 4 FirstFirst 1234 LastLast
Results 13 to 24 of 41
Plumbing & Plumbers Forum - How long does it take to service a boiler?
Like Tree20Likes
Discuss How long does it take to service a boiler? at UK Plumbers Forums; Originally Posted by kasser I have no issues (yet). There were 2 of them and they said it would take 20 minutes, though I didn't note how long they actually ...
  1. #13
    Masood's Avatar
    East London / Essex border
    4,823
    Default Re: How long does it take to service a boiler?
    Quote Originally Posted by kasser View Post
    I have no issues (yet). There were 2 of them and they said it would take 20 minutes, though I didn't note how long they actually took.
    20 minutes sounds faster than what I've read it's supposed to take, 30 - 60 min. Two of them sounds like it should be faster but I doubt you can have two people working on a boiler at the same time?
    My concern is that I am unable to actually verify what they've done.
    It's easy to check the work of a bricklayer - wall goes up, a plumber fixes a leak, all dry, boiler install, hot water available, etc.. but boiler servicing? In 20 minutes? And as I said, it's not new.
    OK - 20 minutes is fast, but with easy access it is possible to service a newer model Worcester to manufacturer's spec in that time if you're slick and know the boiler inside out, and - importantly - the boiler is already up to operating temperature.
    It's not always necessary to strip the boiler down..
    Last Plumber and jtsplumbing like this.
    Find us at:
  2. #14
    Chalked's Avatar
    3,918
    It depends what some regard as a service.
    There are, on certain models things that must be carried out and things that should be carried out.
    A calibrated flue gas analyser with the right guy operating it. will say in a few seconds weather a full strip down is required. Or other issues. As will a gas rate.
    But in my Veiw a service is not just a check, it's doing the right work on an appliance, so that with best intentions, it should operate safely, efficiently and reliably for the next 12 months. Too many, just stick the probe in the flue and say it's fine.
    Last Plumber and Masood like this.
  3. #15
    Last Plumber's Avatar
    Aug 2016
    Lancashire
    1,391
    I would expect it to take at least 45 min including gas tightness testing etc. It does depend a lot on what they call a service.
    You can't tell if they've done it, just like you cant tell if your car has been fully serviced unless you know what you're looking for.
    Did you employ Gas Safe Registered Engineers?
  4. #16
    A1P
    A1P is offline
    Bradford,West Yorkshire
    191
    And how do I verify that it has actually been serviced and it was not just a safety check being carried out?
    In boiler servicing ,as in car servicing,there is an element of trust.You often cannot see anything obvious for your 'hard earned.'As regards 20 mins and 2 men,possibly a bit light on time,Worcester's can take longer than some.As for 2 men ,possibly engineer plus apprentice.In the end try to use a tradesman you trust on a regular basis.When I fit a boiler I do it in the hope the customer will use me to service it according to MI instructions on a regular basis.Good for both parties.
    Last Plumber likes this.
  5. #17
    Nov 2016
    20
    That's what I was getting at and not being a gas engineer, I can't tell much. There should be a form/report (perhaps there is), stating what has been done and values noted down. I believe an electrical safety check has such a certificate/report.
  6. #18
    Nov 2016
    20
    Yes, engineer is gas safe registered. I don't think I got a receipt for the payment.
  7. #19
    Nov 2016
    20
    By the way, being gas safe registered doesn't mean he will do the job properly?
    As long as he leaves the boiler in a safe condition, Gas Safe won't be on his back. So servicing could mean sticking a probe in there and that's it, even for a Gas Safe engineer...?
  8. #20
    Aug 2016
    Lancashire
    1,391
    I always print off a FGA ticket but to be honest with you, it means nothing to most customers so I keep them myself on file for twelve month just in case I need to reference it for anything.
    ( I have never had to though).
    I also fill in the service sheet at the rear of the installation manual with comments and CO2/CO Ratio and a few of the other readings. Again, that is more use to any future engineers or myself than the customer.
    jtsplumbing, A1P and ShaunCorbs like this.
  9. #21
    Aug 2016
    Lancashire
    1,391
    You're quite correct. Just because he/she is registered doesn't mean they are thorough.
    What can you do?
    Use a recommended engineer, If you want a full strip down service on your boiler, ( even though you may not need it), you can always ask but it will cost more in time and materials.
    jtsplumbing and AlexGas like this.
  10. #22
    Responsible Moderator...
    APPlumbing's Avatar
    Locks Heath fareham
    13,460
    How much was the service? If that's not too nosey!!
    scott_d likes this.
    I have an unfortunate problem. I should stand upwind if I were you!
  11. #23
    9,980
    20 mins will be a check
    We allow 45-60 mins
    Tightness test gas system
    Visual check of gas line and meter
    Boiler flue check
    Check system pressure and top up
    Cover off and clean inside (Hoover etc)
    Check expansion pressure
    Clean trap
    Check probes
    Fga boiler max and min rate
    Gas rate appliance
    Cover back on
    Fill out paper work and email to client
    I've cropped out the address but you get the idea
    Good luck doing that any faster
    CHRISX and turnpin like this.
  12. #24
    scott_d's Avatar
    Nov 2012
    BRISTOL
    1,580
    Quote Originally Posted by APPlumbing View Post
    Could be another group-on service deal
  1. Long distance from boiler to tap
    By TAKdriver in forum Plumbing Forum
    Last Post: 20-03-2015, 09:55 AM
  2. How long to hang a boiler?
    By that bloke. in forum Central Heating Forum
    Last Post: 29-03-2011, 10:33 AM
  3. Boiler on too long
    By Jilly in forum Plumbing Forum
    Last Post: 25-11-2010, 08:55 PM
  4. How long it takes on average to service an oil fired boiler?
    By OFTEC in forum Oil and Solid Fuel Forum
    Last Post: 23-11-2010, 02:37 PM
  5. How long it takes on average to service an oil fired boiler?
    By OFTEC in forum Central Heating Forum
