Results 1 to 6 of 6
Plumbing & Plumbers Forum - Alpha InTec C Gas valve / controls Q
  • 1 Post By chris watkins
Discuss Alpha InTec C Gas valve / controls Q at UK Plumbers Forums; Good Evening, Where could I ask some questions or 'who' could I ask some questions about controls with boilers?...
    Mar 2013
    21
    Default Alpha InTec C Gas valve / controls Q
    Good Evening,
    Last Plumber's Avatar
    Aug 2016
    Lancashire
    1,131
    Default Re: Alpha InTec C Gas valve / controls Q
    What are you revising ?
    Are you Gas Safe Registered?
    Mar 2013
    21
    Quote Originally Posted by Last Plumber View Post
    AlexGas's Avatar
    Sunny Southampton
    2,870
    Quote Originally Posted by Dom Perkins View Post
    Im on an initial course into the gas industry, so I'm a student. All questions are hypothetical to be honest, although i may have to work on it in a workshop if asked.
    Talk to your teacher/lecturer.
    Make it happen!
    Jun 2012
    London/Kent
    3,950
    Good Evening,
    I've used this forum for a while now, mainly finding thing's already covered and so not needing to actually speak to anyone. Im currently doing some revision and wanted to know what the 'controls' on an Alpha InTec C boiler would be. Obviously there is a gas valve, is it multi-functional though?
    I.e has a regulator/thermocouple/solenoid - or am i way off?..there is a black plastic block with a plug on it which i am assuming is a solenoid.. Way off, this is a modern condensing boiler you need to do some research on zero rated gas valves.
    There is also an electrode coming from the burner chamber on the left side and one on the right, would the left one be a flame rectification control of some sort? M.I states Flame sensing electrode...so a Electronic flame supervision device? How does this work then ? Why does the flame need supervision?
    This is the link to the boiler:http://www.alpha-innovation.co.uk/pr...c+C/3707668722
    anymore info would be greatly appreciated, cheers in advance.
    We have to be careful in open forum with the info provided so hope that helps.
    Answer a few questions & you never know the Mod's might be able to help with access to a safer place.
    turnpin likes this.
  6. The Following User Says Thank You to chris watkins For This Useful Post:
    Mar 2013
    21
    Quote Originally Posted by chris watkins View Post
    Ok, If the information shouldn't be published here that makes sense. I will edit the post and see if there is a more appropriate place for it to be.
  8. The Following User Says Thank You to Dom Perkins For This Useful Post:
  1. alpha intec 28x
    By jonnyboy in forum Gas Safe Register Forum - Public Forum
    Last Post: 02-05-2013, 10:43 PM
  2. alpha intec 28x
    By jonnyboy in forum Central Heating Forum
