Results 1 to 6 of 6
Plumbing & Plumbers Forum - Imperial gas meter has 2 lead output pipes
Like Tree2Likes
  • 1 Post By Riley
  • 1 Post By firemant
Discuss Imperial gas meter has 2 lead output pipes at UK Plumbers Forums; Hello all. This post is regarding the configuration of outlet pipes from an imperial gas meter both pipes are lead. A 22mm and a 15mm pipe branching off from it. ...
    Nov 2014
    North West/UK
    17
    Question Imperial gas meter has 2 lead output pipes
    Hello all.
    A 22mm and a 15mm pipe branching off from it. Something I havent seen before.
    Has anyone seen this configuration before?
    Why the main pipe and a branch off?
    Is it best to replace for complete copper pipes?
    It appears someone in the past has connected the lead outlet pipes to copper pipes.
    As the house has 3 appliances situated in different locations and as far as I can see under the floor
    boards the appliances are fed by copper pipes not lead.
    Any tips would be welcome.
    Attached Thumbnails Attached Thumbnails Imperial gas meter has 2 lead output pipes-tmp_13926-screenshot_2017-01-01-21-52   Imperial gas meter has 2 lead output pipes-tmp_13926-screenshot_2017-01-01-21-52
    Riley's Avatar
    Sarf Coast
    6,390
    Default Re: Imperial gas meter has 2 lead output pipes
    Dude Gas questions. Get your details to a mod and we can help you. Not in open forum though
    Masood likes this.
  3. The Following User Says Thank You to Riley For This Useful Post:
    Masood's Avatar
    East London / Essex border
    4,769
    A lot depends on who you are and why you're asking the question, to be frank. Is there a leak? A smell of gas? Has someone told you that the lead pipes are a problem? If so, for what reason?
    We can't give detailed, specific advice but in general terms we could steer you in the right direction, which may be to reassure you or to suggest you get a Gas Safe registered engineer in...
    Find us at:
    1,996
    Quote Originally Posted by ckyens View Post
    Has anyone seen this configuration before? YES
    Why the main pipe and a branch off? GAS FIRE / COOKER maybe
    Is it best to replace for complete copper pipes? Depends if someone wants to pay for it.
    It appears someone in the past has connected the lead outlet pipes to copper pipes. Very common at one time, that'll be,, connected copper to existing lead.
    For the rest see other posts.
    May 2013
    260
    Most gas men could not do that now
    Last Plumber likes this.
    PLEASE PLEASE consider signong up for Organ Donation.
    Potentially give back a life to a Kidney patient. It is free and easy:
    https://www.organdonation.nhs.uk/register-to-donate/
    Last Plumber's Avatar
    Aug 2016
    Lancashire
    1,131
    This one can !
    Not many opportunities anymore !
  1. Lead pipe from gas meter through a wall?
    By azif in forum Plumbing Forum
    Last Post: 03-08-2015, 03:48 PM
  2. Lead pipe from gas meter through a wall?
    By Unregistered in forum Plumbing Forum
    Last Post: 01-08-2015, 01:17 PM
  3. 1/2 inch imperial copper to big for end feed imperial??
    By johnmcginty in forum Fittings & Pipes
    Last Post: 01-07-2010, 02:39 AM
  4. Lead pipe meter outlet
    By midge in forum Gas Safe Register Forum - Public Forum
    Last Post: 21-02-2010, 09:27 AM
