Plumbing & Plumbers Forum - Worcester 30CDI pressure problem from yesterday, Help please....
Discuss Worcester 30CDI pressure problem from yesterday, Help please.... at UK Plumbers Forums; Right guys, I found the problem, 1 of the valves was leaking from the pipe were the screw thread is, only found it as the water was dripping through the ...
    13
    Default Worcester 30CDI pressure problem from yesterday, Help please....
    Right guys, I found the problem, 1 of the valves was leaking from the pipe were the screw thread is, only found it as the water was dripping through the brickwork into the conservatory,
    Anyway I drained a bit of the system to change the valve and refilled and bleed all the radiators but the problem I have now is when I turned the heating on there is a trickeling sound from one of the upstairs radiators.
    I turned the heating on and off a few times last night but each time I turned it back on I heard the trickeling.
    All the radiators heat up its just the trickeling as I turn it on.????
    I dont want to sound thick as I havent muck knowledge of heating systems but have you any ideas on what this is and how to solve it.
    Thanks Guys
    Oct 2008
    119
    Default Re: Worcester 30CDI pressure problem from yesterday, Help please....
    Have you bled all the rads?
    13
    I have, except for the one I have off in the back bedroom to decorate, it is the front bedroom that has the trickeling sound when turned on.
    moony's Avatar
    Oct 2009
    1,250
    bled when cold ?
    13
    Yes, I guess I need to put the rad back on to get it to full working order? or doesnt it matter.?
    Oct 2008
    119
    Yes mate, it does matter. Once it's on fill up, pressure up on boiler and bleed again. Should stop the trikling noise!!
    13
    Thanks 'Rob' will give it a rty once the room has been plastered this weekend.
    Thanks for all your help guys.
    Daz.
  1. Worcester 30cdi system pressure problem
    By alexlindley in forum Plumbing Forum
    Last Post: 27-04-2015, 06:48 PM
  2. Problem with dt20 programmer on worcester 30cdi system boiler
    By awme3333 in forum Central Heating Forum
    Last Post: 26-04-2013, 07:14 PM
  3. Worcester 30cdi
    By ethan.j in forum Central Heating Forum
    Last Post: 22-12-2011, 06:55 AM
  4. Low water pressure problem Worcester 24i
    By alexus87 in forum Central Heating Forum
    Last Post: 03-01-2011, 09:35 PM
  5. Worcester greenstar 24i problem topping up pressure
    By ceb in forum Central Heating Forum
    Last Post: 27-11-2010, 09:04 AM
  6. Replies: 6
    Last Post: 22-04-2010, 07:17 AM
  7. Worcester 35CDi pressure problem
    By Freddie100 in forum Central Heating Forum
    Last Post: 24-02-2010, 09:25 PM
