Page 6 of 10 FirstFirst ... 3456789 ... LastLast
Results 61 to 72 of 118
Plumbing & Plumbers Forum - Can you sign off an installation done by a non-GSR plumber?
Like Tree110Likes
Discuss Can you sign off an installation done by a non-GSR plumber? at UK Plumbers Forums; I like grass man. Smoke it til the cows come home babeee...
  1. #61
    newcastle phill's Avatar
    Jan 2014
    3,464
    Default Re: Can you sign off an installation done by a non-GSR plumber?
    dancinplumba and croppie like this.
    Using Tapatalk
  2. #62
    Feb 2015
    Devon
    That escalated quickly....
  3. #63
    stevetheplumber's Avatar
    east london
    10,613
    Quote Originally Posted by Riley View Post
    it's a definite no no. When you service you don't scrutinise every single part of the installation for example is the gas pipe installed to standard where it disappears into the floor. I would assume there is nobody here that will go pulling up floorboards just to check the gas pipe run for example? Why not? Because you have to make a certain degree of assumption that the person who installed it knew what they were doing. If you are signing off someone else's work then you have no confirmation that everything has been installed to standard unless you demolish it and start again in which case what's the point
    so when you fit a new boiler you remove all the boards to inspect the existing gas run ?or do you ask for the bench mark for the twenty year old boiler your just about to rip out ? goes back to what i said we all certify other peoples work
  4. #64
    Riley's Avatar
    Sarf Coast
    6,376
    If I was doing an install I would because you never know what the previous person has done in terms of pipe sizing. I've seen it where the whole run was in 15mm up to about a meter from the boiler when it was upsized to 22mm then comically back to 15mm to go n the boilers gas fitting
  5. #65
    Jan 2014
    3,464
    I had one just like that the other day.
    22 through the worktop into boiler.
    Come the day of the install. Pull the cupboards out and 15mm behind backs and along and under floor onto the original 22mm line.
    Had to up size it all to 22mm except about 18 inches i couldnt get too. Due to brand new flooring.
    Fortunately all working pressures were fine at conclusion but deffo would not have been.
    Riley likes this.
    Using Tapatalk
  6. #66
    Mar 2016
    48
    I have been asked many times, I usually say yes, it's £600. When asked why it's so much I tell them that I become responsible for the whole installation and I need to check absolutely everything about it.
    Not had any takers so far
    newcastle phill likes this.
  7. #67
    Forum Thug
    croppie's Avatar
    23,718
    Quote Originally Posted by Leezygeezer View Post
    I'd be asking double that.
    Croppie
    (By the way, I'm commercial!)
  8. #68
    rpm
    rpm is online now
    Member rpm's Avatar
    Wherever I lay my hat
    7,822
    That be cos your commercial !
    lol
    Riley and croppie like this.
  9. #69
    Mar 2016
    48
    Sorry, that was my up north price, now I'm in the south I'll have to lift it to £1000
  10. #70
    Jan 2014
    3,464
    Up north price ???
    A can of fanta and a bag of chips does it
    Using Tapatalk
  11. #71
    Mar 2016
    48
    Haha, more like a couple of cans of d & b and fish and chips, prices have gone up a bit you know
  12. #72
    Jun 2011
    571
    I can remember the days when Gas Safe didnt exist and there was no certification procedure. I dont have boilers on my ticket at the moment but have plenty of experience under my belt and wouldnt think twice about fitting/replacing my own.
  1. Boiler Installation sign off
    By deanomc in forum Central Heating Forum
    Last Post: 06-05-2015, 09:18 PM
  2. GS engineer required to sign off boiler installation in LU7 0HY area please
    By Sprintmancolin in forum I'm looking for a Plumber or Gas Engineer
    Last Post: 07-05-2014, 09:44 AM
  3. Sign this...
    By Archy Styrigg in forum Plumbing Forum
    Last Post: 01-07-2012, 02:40 AM
Non gsr plumber do
