Page 2 of 10 FirstFirst 12345 ... LastLast
Results 13 to 24 of 120
Plumbing & Plumbers Forum - Can you sign off an installation done by a non-GSR plumber?
Like Tree110Likes
Discuss Can you sign off an installation done by a non-GSR plumber? at UK Plumbers Forums; Originally Posted by stevetheplumber im still of the opinion that we all sign of someone elses work every time we do a landlords cert I see where you're coming from ...
  1. #13
    Masood's Avatar
    East London / Essex border
    4,828
    Default Re: Can you sign off an installation done by a non-GSR plumber?
    I see where you're coming from but the requirements for commissioning and compliance certificate are much more in-depth than a landlord cert. Obviously it wouldn't be practical to do a full recommission every year, but we take on trust that the commisioning engineer did it right, so we are doing mare "maintenance" checks.
    Find us at:
  2. #14
    spanner's Avatar
    Aug 2010
    Archway, London UK
    1,112
    [QUOTE=croppie;832082]Think I'll sticky this thread.[/QUOTE
    Me sticky this thread 102%
    Safety Message
    CARBON MONOXIDE CAN BE FATAL THIS IS A RESULT OF POORLY MAINTAINED APPLIANCES DO NOT LEAVE IT TO CHANCE GET YOUR APPLIANCE SERVICED TODAY!!!
    If it aint broke don't try to fixit
  3. #15
    Banned
    Oct 2014
    45
    Can t see the problem with it as long as its checked over properly whats the difference between that and doing a service.when you service a boiler you dont know if its been installed correctly until you look at it yourself.
  4. #16
    Riley's Avatar
    Sarf Coast
    6,480
    Quote Originally Posted by mooey View Post
    it's a definite no no. When you service you don't scrutinise every single part of the installation for example is the gas pipe installed to standard where it disappears into the floor. I would assume there is nobody here that will go pulling up floorboards just to check the gas pipe run for example? Why not? Because you have to make a certain degree of assumption that the person who installed it knew what they were doing. If you are signing off someone else's work then you have no confirmation that everything has been installed to standard unless you demolish it and start again in which case what's the point
    spanner and mountainman like this.
  5. #17
    spanner's Avatar
    Aug 2010
    Archway, London UK
    1,112
    As above 102%. As Riley says. And guess if anything were to go wrong with a new installation Doing that it just means trouble. For me. I always make sure I'm on track. As to communicating I might have missed out on something myself, but at least i know I'll have piece of mind to have the task properly answered. As to being gas safe registered. It's not the "end of"! To me it's always a new beginning and keeping updated on a basis.
    As to servicing, had a few bad starts here and only made me think again I'm learning here.
    But a deffo no when or if it comes to that. I'd rather not be considered.
    At the least is having to check and doing a let by tightness test with tiny untraceable leakage.
    OR working with ALL appliances and not having enough due for undersized pipework.
    Safety Message
  6. #18
    Riley's Avatar
    Sarf Coast
    6,480
    I knew someone would come straight back with an argument like that. Showing once again that the public are not informed by the body ie Gas Safe
  7. #19
    AlexGas's Avatar
    Sunny Southampton
    2,884
    Can t see the problem with it...
    Can you sign off an installation done by a non-GSR plumber?-like-bill-gas-safe.jpg
    Make it happen!
  8. #20
    1,413
    Quote Originally Posted by AlexGas View Post
    Click image for larger version.
    Can I use this image please Alex?
  9. #21
    rpm
    rpm is offline
    Member rpm's Avatar
    Wherever I lay my hat
    7,964
    You can`t see the problem and I can`t see your gsr badge! Neither can I see the point in coming back to something from 2015 unless it concerns you directly.
    Riley, croppie and AlexGas like this.
  10. #22
    AlexGas's Avatar
    Sunny Southampton
    2,884
    Quote Originally Posted by dave1 View Post
    No probs, Dave, help yourself.
    Make it happen!
  11. #23
    Jan 2011
    Charing
    1,057
    You could do if you wanted to, but if it all goes tits up, the authorities will be coming your way?
    Geyser likes this.
    Need an Alpha boiler repair or a service? If you're in Kent then give Alpha man a call to arrange a visit. Telephone 01233 712994, Steve, of Greenside Heating Services, GSR number 296.
    Sorry, no free technical advise given to the public either over the Internet or telephone.
    I will only visit if you're in KENT
    (I'm not Alpha nor work for them, just an Independant engineer.)
    Steve
  12. #24
    newcastle phill's Avatar
    Jan 2014
    3,652
    This was in last months gas rag. Gas lad got hammered big time
    Using Tapatalk
  1. Boiler Installation sign off
    By deanomc in forum Central Heating Forum
    Last Post: 06-05-2015, 09:18 PM
  2. GS engineer required to sign off boiler installation in LU7 0HY area please
    By Sprintmancolin in forum I'm looking for a Plumber or Gas Engineer
    Last Post: 07-05-2014, 09:44 AM
  3. Sign this...
    By Archy Styrigg in forum Plumbing Forum
    Last Post: 01-07-2012, 02:40 AM
Non gsr plumber do
