Page 6 of 9 FirstFirst ... 3456789 LastLast
Results 61 to 72 of 108
Plumbing & Plumbers Forum - Gas Safe Engineers
Like Tree108Likes
Gas Safe Engineers
Discuss Gas Safe Engineers at UK Plumbers Forums; Originally Posted by Bernie2 Not knowing possibly causes more accidents than information. In the gsr industry people seem largely not knowing about safety and do not see the reason for ...
  1. #61
    Forum Thug
    croppie's Avatar
    23,822
    Default Re: Gas Safe Engineers
    Quote Originally Posted by Bernie2 View Post
    Not knowing possibly causes more accidents than information. In the gsr industry people seem largely not knowing about safety and do not see the reason for danger until you tell them. But the Gas Safety Register is supposed to help ensure peoples safety but possibly only if they know what they are being kept safe from. If a person thinks getting in a gsr fitter is going to cost them far more that they can afford and they think the job is easy based on not knowing they will probably have a go themselves. That is not promoting safe practices. By giving out information you are warning them as to the dangers, if they then go ahead and still do it, that problem is theirs. You at least tried to warn them it was not simple. Anyway they can always buy Torreys or Viper books they have been available for years to the general public. A GSR fitters job is to promote safety not form a secret club.
    How many times do I have to say no?
    Croppie
    (By the way, I'm commercial!)
  2. #62
    Forum Thug
    croppie's Avatar
    23,822
    Another one that i often get into arguments over is site generators. Why do carpenters and others think its ok to use a generator by the front door or even worse just inside the property. I even had one carpenter who laughted at me when i told him to move his generator from the front door of the house we were both working in.
    Its one thing to be stupid enough to kill yourself, its another to put others health at risk or even worse murder somebody.
    I had to run a genny in the back of my van earlier this year because it was too large to pull out on my own. I had all the doors open while I was working but thought i'd leave a CO monitor on the dashboard while i was working.
    Bearing in mind the van was ventilated and there's a bulkhead fitted the CO detector peaked at 470ppm after only 5 minutes running! (I was fusion welding an LPG service pipe in the middle of a field.)
    Needless to say I made sure the genny was turned off and all the doors remained open a good half hour before I got in the van!
    AWheating, stoker122 and IDCHAPPY like this.
    Croppie
  3. #63
    uɐɯ sɐƃ moderator
    gas man's Avatar
    18,737
    if you dont like the way we promote gas safety on this site bernie or agree with the orange headings we would rather you not contribute to the forums,you are on some sort of mission to undermine what we are trying to achieve there is no secret club we just dot want anyone to die by the advice given on here
  4. #64
    AWheating's Avatar
    WestMidlands
    9,638
    atleast you used your head.
    it does not take very long for co off a generator to get to dangerous levels. In the USA there are alot of deaths every year from generators, They keep them for backup power when hurricane/twister season hit. Many get them out and use them in there safe room/shelter when the powers down.
    you also have to take into consideration your PLI, my old policy required a generator to be used 3m from property to avoid fire damage. I worked on a site many years ago where the plasterer filled his up while smoking, he drop his fag and it when up. His problem was the generator was inside the front door and it burnt half the house down.
    croppie likes this.
    He who dares Wins, unless he dares to try and breath under water.
  5. #65
    Banned
    Mar 2009
    Liverpool
    1,984
    We can all do stupid things Croppie and publish it on the website making others think its okay. Seems to me we might be using a set of double standards which says some people can do what ever they want but others must do as they are told. One of the main safety factors is knowledge. A popular DIY expert was on the TV recently and said, I know all about how that thing works but I am not qualified to fix it. It was his knowledge that stopped him DIYing not his ignorance. Incidentally you and "gas man" give me the impression that you now own this site now or is Dan still the boss?Incidentally I was once a moderator on the site for a short time, so I know how far your brief extends. Its a Plumbers forum not a gas fitters and one that is supposedly welcome to all, so lets be a bit more tolerant to others please. If you want to keep things secret go off line and e-mail each other, secrecy is not what a forum is supposed to be about. I know what your viewpoint is, I just do not agree with it that is all. But you seem to project a threatening and bullying attitude all the time, perhaps not intentionally but you still seem to do it.
  6. #66
    Forum Thug
    croppie's Avatar
    23,822
    Think I understand why you were a mod for only a short while. If a point blank "NO! These are the forum rules! You need to be of the class of person who is proven and qualified to work on gas and gas appliances as described in the Gas Safety (Installation and Use) Regulations 1998." cannot be understood nor comprehended then there is something seriously wrong with that individual.
    And if you see that as threatening or bullying then you have led a very sheltered life!
    Atouchofgas and Ermintrude like this.
    Croppie
  7. #67
    BOD
    BOD is offline
    Administrator BOD's Avatar
    Nov 2009
    13,817
    And maybe "the brief" was changed after learning from mistakes made in the past
  8. #68
    Jun 2013
    In my experience you have to know who you are dealing with before giving out advise relating to gas work and the context it will be used for. A piece of advise may cover one point, what about the other five points that have to be tested for the work to be safe. A little knowledge can be dangerous, all for the forum rules myself
  9. #69
    Banned
    Mar 2009
    Liverpool
    1,984
    Markus, if we ask ourselves, did the people who taught us gas fitting ask whether we where suitable to know it, answers that question. I am all for people knowing about gas, its just that the courses relating to safety should be free. The training of gas fitters in the past was usually undertaken mostly by the companies who wanted to use gas fitters. The modern idea of courses leaves it open to anybody so there is no real point in asking who is suitable to know about gas and who is not. As I have said before there is nothing wrong with giving advice it is the person who receives the advices responsibility to use it properly. The same way as a gas tutor views it when he teaches students. So if you inform people about the legal requirements of gas fitting before you tell them and give a disclaimer there is no real reason why you should not tell people.
  10. #70
    Plumbers Arms member Kyle87's Avatar
    leicester
    2,391
    I don't agree. That's like saying here's a gun. Ill tell you how to use it but if you kill someone that's your fault not mine.
    People who undertake gas training have spent a lot of money on it. Like me. They are potential engineers. And obviously seek gas registration in the future.
    People on the open forum may be potential engineers also with good intentions ( like myself ). But they may also be diyers or cowboys looking to abuse the info they receive. I
    Don't blame ukpf for not taking the chance.
    I'd love to be in the GSR only forum as I'd learn a ton. But I understand why I'm not allowed.
    Bernie......give up the fight mate!!
    SimonG, Ermintrude and croppie like this.
    There aint a devil.....its just god when hes drunk!! :devil:
    There's a good reason they call me Pork Chop!
  11. #71
    leicester
    2,391
    Actually I was wrong to use a gun in comparison to gas. A gun isn't going to take a tower block out.
    I should have said Bazooka!!
    croppie likes this.
  12. #72
    Mar 2011
    Roscommon(Eire)
    93
    Thats where you're argument falls down, trusting others to work safely, stupid people(their out there )rarely know they are stupid so shouldn't be encouraged to fiddle by a Internet forum, although that goes against my views on natural selection.
    croppie likes this.
  1. hello
    By uug197h in forum New Member Introductions
    Last Post: 15-10-2015, 08:19 AM
  2. Non gas safe engineers
    By Millsy 82 in forum Gas Safe Register Forum - Public Forum
    Last Post: 13-06-2013, 06:23 PM
  3. Gas Safe Register Mag & emails for ALL engineers
    By Mrs Tara Plumbi in forum Gas Safe Register Forum - Public Forum
    Last Post: 03-04-2013, 09:02 AM
  4. Gas safe engineers PLEASE READ!!!
    By yourplumbing in forum I'm looking for a Plumber or Gas Engineer
    Last Post: 01-02-2013, 11:43 PM
  5. Gas safe engineers PLEASE READ!!!
    By yourplumbing in forum Gas Safe Register Forum - Public Forum
    Last Post: 31-01-2013, 07:51 PM
  6. A question for Self Employed Gas Safe Engineers
    By rodders in forum Gas Safe Register Forum - Public Forum
    Last Post: 21-01-2013, 02:56 PM
  7. Any Gas safe engineers in the Manchester area?
    By 850Rick in forum I'm looking for a Plumber or Gas Engineer
    Last Post: 19-12-2012, 09:27 AM
  8. D.I.Y Gas Work!!Calling All GAS SAFE ENGINEERS!!!!!
    By Hardy1 in forum Gas Safe Register Forum - Public Forum
    Last Post: 15-03-2012, 11:04 AM
  9. Gas safe engineers-READD Please
    Last Post: 08-11-2011, 11:36 AM
content
