Results 1 to 12 of 12
Plumbing & Plumbers Forum - what could the symptoms be for a high Co/Co2 ratio?
Discuss what could the symptoms be for a high Co/Co2 ratio? at UK Plumbers Forums; Hi everyone, I'd like to know what the common problems/symptoms could be for a higher than normal CO/Co2 ratio when using a Flue Gas Analyser. What should I be looking ...
    Jul 2011
    40
    Default what could the symptoms be for a high Co/Co2 ratio?
    Hi everyone,
    I'd like to know what the common problems/symptoms could be for a higher than normal CO/Co2 ratio when using a Flue Gas Analyser. What should I be looking for i.e correct incoming gas pressure from the meter etc. Are there a few problems which you would always check first and most of the time it tends to be that one thing, or could it be many different reasons on any given job?
    All your helpful answers would be much appreciated..... thanks in advance :-)
    uɐɯ sɐƃ moderator
    gas man's Avatar
    18,738
    Default Re: what could the symptoms be for a high Co/Co2 ratio?
    what boiler? on most SE appliances gas pressures being over set would be my first check
    Jul 2011
    40
    I tend to find Worcesters and Vaillants have higher ratios, whereas MAIN's and Ideal are quiet low, often 0.0001.
    Mar 2012
    6,912
    i think alot of MI's state if you get a high reading they recommend a strip and clean then re check , could be wrong tho
    Jul 2011
    40
    Im sure they do........ but strip and clean what exactly??
    Also Gas Man, what are SE appliances??
    uɐɯ sɐƃ moderator
    gas man's Avatar
    18,738
    Quote Originally Posted by neddy1984 View Post
    im sure they do........ But strip and clean what exactly??
    Also gas man, what are se appliances??
    standard efficiency
    villa_tom's Avatar
    Sep 2010
    The Midlands
    4,261
    Any set of manufacturers instructions will tell you what ratio you need to achieve and what to do if it's out. If you adjust the ratio at the gas valve etc and yo still can't obtain a good reading then yo have to check reasons why, ie gas pressure, flue integrity etc. if these are ok then a full strip and clean will be need, which you can find in the MI's.
    If you could read my mind I'd get punched in the face a lot
    Forum Thug
    croppie's Avatar
    23,832
    There's a range of boilers I look after on the commercial side, Potterton condensing Derwent, which are thankfully obsolete now, I get issues with them with the fan assembly. Burner pressure on the nose, boiler sparkling inside (and out!) but dreadful fga readings, the fan loses 10-20% of speed through wear and tear. Generates enough air to activate the aps but doesn't pull the flue gases through fast enough.
    Horrible boilers. A new fan is the best part of a monkey and becoming increasingly more difficult to get hold of. Every one I go to I report the thing as life expired...... Sometimes I love government work!
    Croppie
    (By the way, I'm commercial!)
    Blake's Avatar
    Jun 2008
    Nottingham
    1,064
    Quote Originally Posted by Neddy1984 View Post
    Have you done your CPA1? I only ask as this should have been explained during your training and if you are not sure what you should be cleaning in order to try and achieve the correct results you probably need to re-read all of your training notes. IMHO.
    946
    First thing to check fga working and been calibrated
    AWheating's Avatar
    WestMidlands
    9,638
    basically it can be anything involved in the combustion process......from the gas main/meter to the flue terminal and the correct operation and use of your analyser.
    He who dares Wins, unless he dares to try and breath under water.
    Member arran197's Avatar
    Aug 2011
    Wolverhampton
    1,294
    Gas pressure is the easiest thing to start with, obviously BP and IWP on old boilers and just IWP on new ones. From there you need to be gas rating and checking the integrity of the flue. On some condensing boilers the gas valve is adjustable to get the perfect ration and co2 percentage. But you need to make sure you follow the right procedure for adjusting any gas valve. The amount of times I have come across Greenstars that have been incorrectly adjusted is not funny. Especially the older ones like the R series. Manufacturers are always glad to guide you through how to adjust the thing, just call them and ask. No one is going to knock you for getting extra information about an appliance.
  1. Vokera 14e pressure drop odd symptoms
    By rytenuff in forum Central Heating Forum
    Last Post: 16-09-2013, 06:39 AM
  2. Symptoms and problems associated with low inlet working pressure (forced draught).
    By bennygas in forum Gas Safe Register Forum - Public Forum
    Last Post: 03-04-2012, 10:01 PM
  3. High Pressure and leaks - Halstead Ace High combi
    By Sir Monkfish in forum Central Heating Forum
    Last Post: 01-02-2012, 11:57 PM
  4. Symptoms of faulty Gas meter
    By Rizme in forum Gas Safe Register Forum - Public Forum
    Last Post: 16-01-2012, 12:16 AM
  5. symptoms of a faulty pressure vessel
    By Ralphmalph in forum Central Heating Forum
    Last Post: 12-11-2011, 12:27 AM
  6. Symptoms of low level gas poisionng??
    By mredd in forum Gas Safe Register Forum - Public Forum
    Last Post: 11-02-2011, 01:22 AM
  7. Withdrawal symptoms
    By Dannypipe in forum General Off-Topic Chat
    Last Post: 07-09-2010, 10:25 PM
  8. Power shower minimum head symptoms
    By parca in forum Bathrooms, Showers and Wetrooms
    Last Post: 06-12-2009, 12:11 PM
high co co2 ratio
boiler co2 readings
co co2 ratio
flue gas analyser ratio high
ideal independent c35 boiler very high co ratio
