Results 1 to 12 of 12
Plumbing & Plumbers Forum - what could the symptoms be for a high Co/Co2 ratio?
Discuss what could the symptoms be for a high Co/Co2 ratio? in the Gas Safe Register Forum - Public Forum at Plumbers Forums; Hi everyone, I'd like to know what the common problems/symptoms could be for a higher than normal CO/Co2 ratio when using a Flue Gas Analyser. What should I be looking ...-
22-08-2012 #1Plumbing Forum Contributor
- Jul 2011
- 36
- 14
Hi everyone,
I'd like to know what the common problems/symptoms could be for a higher than normal CO/Co2 ratio when using a Flue Gas Analyser. What should I be looking for i.e correct incoming gas pressure from the meter etc. Are there a few problems which you would always check first and most of the time it tends to be that one thing, or could it be many different reasons on any given job?
All your helpful answers would be much appreciated..... thanks in advance :-)
22-08-2012 #2uɐɯ sɐƃ moderator
- Jan 2010
- maesteg,south wales
- 13,319
- 827
- Thanked 1,264 Times in 1,207 Posts
Re: what could the symptoms be for a high Co/Co2 ratio?
what boiler? on most SE appliances gas pressures being over set would be my first check
GASMAN
22-08-2012 #3Plumbing Forum Contributor
- Jul 2011
- 36
- 14
I tend to find Worcesters and Vaillants have higher ratios, whereas MAIN's and Ideal are quiet low, often 0.0001.
22-08-2012 #4Plumbers Arms member
- Mar 2012
- 1,874
- 90
- Thanked 71 Times in 70 Posts
i think alot of MI's state if you get a high reading they recommend a strip and clean then re check , could be wrong tho
22-08-2012 #5Plumbing Forum Contributor
- Jul 2011
- 36
- 14
Im sure they do........ but strip and clean what exactly??
Also Gas Man, what are SE appliances??
22-08-2012 #6uɐɯ sɐƃ moderator
- Jan 2010
- 13,319
- 827
GASMAN
22-08-2012 #7UK Plumbersforums Trusted Advisor.
- Sep 2010
- The Midlands
- 3,427
- 225
- Thanked 260 Times in 240 Posts
Any set of manufacturers instructions will tell you what ratio you need to achieve and what to do if it's out. If you adjust the ratio at the gas valve etc and yo still can't obtain a good reading then yo have to check reasons why, ie gas pressure, flue integrity etc. if these are ok then a full strip and clean will be need, which you can find in the MI's.
If you could read my mind I'd get punched in the face a lot
22-08-2012 #8Moderator
- Jul 2010
- Portadown, United Kingdom
- 7,586
- 445
- Thanked 528 Times in 489 Posts
There's a range of boilers I look after on the commercial side, Potterton condensing Derwent, which are thankfully obsolete now, I get issues with them with the fan assembly. Burner pressure on the nose, boiler sparkling inside (and out!) but dreadful fga readings, the fan loses 10-20% of speed through wear and tear. Generates enough air to activate the aps but doesn't pull the flue gases through fast enough.
Horrible boilers. A new fan is the best part of a monkey and becoming increasingly more difficult to get hold of. Every one I go to I report the thing as life expired...... Sometimes I love government work!Propino Tibi Salutem! Usque ad Mortem Bibendum!
Croppie
(By the way, I'm commercial!)
23-08-2012 #9Plumbers Arms member
- Jun 2008
- Nottingham
- 1,064
- 20
- Thanked 107 Times in 98 Posts
23-08-2012 #10Top Plumbing Forum Contributor
- Apr 2011
- 751
First thing to check fga working and been calibrated
23-08-2012 #11UK Plumbersforums Trusted Advisor.
- Dec 2010
- WestMidlands
- 5,786
- 124
basically it can be anything involved in the combustion process......from the gas main/meter to the flue terminal and the correct operation and use of your analyser.
btw im commercial, NOT.
23-08-2012 #12Top Plumbing Forum Contributor
- Aug 2011
- Wolverhampton
- 697
- Thanked 48 Times in 46 Posts
Gas pressure is the easiest thing to start with, obviously BP and IWP on old boilers and just IWP on new ones. From there you need to be gas rating and checking the integrity of the flue. On some condensing boilers the gas valve is adjustable to get the perfect ration and co2 percentage. But you need to make sure you follow the right procedure for adjusting any gas valve. The amount of times I have come across Greenstars that have been incorrectly adjusted is not funny. Especially the older ones like the R series. Manufacturers are always glad to guide you through how to adjust the thing, just call them and ask. No one is going to knock you for getting extra information about an appliance.
Symptoms of faulty Gas meter
By Rizme in forum Gas Safe Register Forum - Public ForumReplies: 8Last Post: 15-01-2012, 11:16 PM -
symptoms of a faulty pressure vessel
By Ralphmalph in forum Central Heating ForumReplies: 11Last Post: 11-11-2011, 11:27 PM -
installed a new vokera 29he compact natural gas, the ratio is 0.0011? is the ratio ok
By cool in forum Gas Safe Register Forum - Public ForumReplies: 12Last Post: 25-06-2011, 11:16 PM -
Symptoms of low level gas poisionng??
By mredd in forum Gas Safe Register Forum - Public ForumReplies: 14Last Post: 11-02-2011, 12:22 AM -
Withdrawal symptoms
By Dannypipe in forum General Off-Topic ChatReplies: 3Last Post: 07-09-2010, 10:25 PM
Incompetent Plumber and SNIPEF
26 Minutes Ago in Plumbing Forum
