Results 1 to 15 of 49
Plumbing & Plumbers Forum - suitable materials for filling gap around flue
Discuss suitable materials for filling gap around flue in the Gas Safe Register Forum - Public Forum at Plumbers Forums; Doing landlords i frequently come across flues with large gaps around them where they pass through walls that have never been filled in, sometimes theres those rubber collars hidding the ...-
09-08-2012 #1
sometimes theres those rubber collars hidding the hole, but often you can look along the flue to daylight
(occasionally on bigger holes i see newspaper stuffed in by the tenant to stop draughts)
I dont why hole are so common, maybe some engineers meant to return to make good others are just plain lazy. needless to say its not really exceptable
to make good, with a small gap i've seen engineers use silicon to seal the hole and on larger gaps expanding foam
logically both would work, both can be purchased with heat resistant qualities, both are hard wearing and should last, and both should stop any air flow or transfer of unwanted gases
however in my gas book it says flues should be sealed with sand and cement, with no mention of any other suitable products.
Is foam and silicon a no no
09-08-2012 #2Plumbers Arms member
- 741
- 7
- Thanked 54 Times in 53 Posts
I work for a HA and I'd say at least 50% flues are not made good it's ridiculous poor workmanship in my opinion. I'd cement them in... However have seen them made good with silicone and other products.
09-08-2012 #3Moderator
- Nov 2009
- THE BEST COUNTY IN THE LAND - YORKSHIRE
- 10,544
- 461
- Thanked 554 Times in 510 Posts
Re: suitable materials for filling gap around flue
Don't some books read a suitable material ? Yet another grey area in our trade lets not forget the outer flue if twin lined is only air flow in
09-08-2012 #4Steady Plumbing Forum Contributor
- Jun 2011
- 106
- Thanked 5 Times in 5 Posts
when i do istalls i stitch drill quite tight, soim notgoin gooutand buy a bag of sand and cement which ive then ot to carry round with me, when i can just use some heat resistand silicone which ive already goton the van
09-08-2012 #5Steady Plumbing Forum Contributor
- Jun 2011
- 106
typing in the dark so there sum mistakes in that last post haha
09-08-2012 #6
09-08-2012 #7Plumbers Arms member
- Apr 2010
- 1,399
- 61
- Thanked 167 Times in 157 Posts
09-08-2012 #8Banned
- Dec 2009
- Portsmouth
- 672
- 64
- Thanked 70 Times in 68 Posts
Who still stitch drills in this day and age?
The last time that I had to was on an install in Paulsgrove. cast concrete walls as hard as nails, with rebar. Core wouldnt even touch it.
As to the OP, I have used all methods exp. foam can be wasteful if using tins, as it would have to be a big gap to use a whole tin.
Sand and cement is my preference.
But then how do you seal the outside wall on a sixth floor install, when flue has been put in from the inside?Last edited by grahamgas; 09-08-2012 at 09:50 PM.
09-08-2012 #9UK Plumbersforums Trusted Advisor.
- Apr 2010
- Scotland
- 9,363
- 281
- Thanked 1,178 Times in 1,045 Posts
I took the baby kango to one on monday. Bloody nofines and i wasn't loosing the tooth off a £100 core bit drilling it.
09-08-2012 #10UK Plumbersforums Trusted Advisor.
- Dec 2010
- WestMidlands
- 5,803
- 124
i worked on simular work, in the end i went around and disconnected and labeled them, gave the tenant the comapny phone number and told them to phone and complain that the boiler is dangerous and has been turned off. Once the HA get wind of the compliants they will start to get patched or the work passed to another company......... give them a quote
btw im commercial, NOT.
09-08-2012 #11UK Plumbersforums Trusted Advisor.
- Dec 2010
- WestMidlands
- 5,803
- 124
an unpatched flue (std flue) is AR unless allowed by the manufacture imo. either patch it or turn off and quote for the patching.
09-08-2012 #12Plumbers Arms member
- Jul 2012
- norfolk
- 303
- 9
- Thanked 13 Times in 13 Posts
speaking to our local vokera breakdown engineer about this very subject and he use fire cement to seal around flues if not done and the gap is not to big. i thought not a bad idea quick and easy, [messey stuff] but not to sure how it will react with the lack of heat?
09-08-2012 #13SUPER MODERATOR
- Jan 2009
- sherrif county
- 9,101
- 241
- Thanked 529 Times in 492 Posts
i use pre mixed tile adhesive if i have some scrags left over from a bathroom job, keep it in a tub and last for ages. takes 2 mins and sticks like ......,sure its heat proof?.
¿ʞɹoʍ sɐƃ
09-08-2012 #14
10-08-2012 #15UK Plumbersforums Trusted Advisor.
- east london
- 6,666
- 9
when we was busy we carried a bag of sand and one of cement
VAT on materials.
By pjfplumbright in forum Plumbing ForumReplies: 7Last Post: 11-06-2012, 11:33 PM -
profit % on materials
By mark_mc in forum Plumbing ForumReplies: 24Last Post: 02-05-2011, 10:08 PM -
Is my boiler suitable?
By GuidancePlease in forum Central Heating ForumReplies: 22Last Post: 16-02-2011, 11:44 PM
12Likes
Any of you underfloor heating...
10 Minutes Ago in Plumbing Forum
