Results 1 to 15 of 15
Plumbing & Plumbers Forum - pipes in screed
  • 1 Post By ambrosia
pipes in screed
Discuss pipes in screed in the Gas Safe Register Forum - Public Forum at Plumbers Forums; Quick question , Am aware that copper needs p[rotecting etc when in a screed but does iron hae any different regs regarding this? I ask this as been asked to ...
    Mar 2012
    1,896
    Default pipes in screed
    Quick question ,
    I ask this as been asked to alter some gas pipes (iron) in a screeded floor.
    east london
    6,666
    Default Re: pipes in screed
    wrap in denso
  3. The Following User Says Thank You to stevetheplumber For This Useful Post:
    hammers4spanner (06-08-2012)
    Mar 2012
    705
    Can you fit iron pipes in a screed floor?
    Mar 2012
    1,896
    Quote Originally Posted by Millsy 82 View Post
    what you mean??
    diamondgas's Avatar
    Newcastle Upon tyne
    6,050
    Water or gas H4S? My concern with gas would be connections in concrete but not sure TBH as stay clear of it! lol
    Mar 2012
    1,896
    Gas DG , i thought you had to be at a minimum depth 50mm screed over the top and had to protect pipes as usual,cant find my viper book so thought go on here and ask .
    diamondgas's Avatar
    Newcastle Upon tyne
    6,050
    Just read me bpec thingy from last year. "In the case of steel and copper pipes, they may be laid on top of the base concrete and subsequently covered by the screed providing that it is protected from corrosion" Hope that helps
  9. The Following User Says Thank You to diamondgas For This Useful Post:
  10. #8
    ambrosia's Avatar
    371
    and as i recall screwed fitting are considered part of the pipe and dont need access
    not that that was part of the question just wanted to sound knowledgeable
    diamondgas likes this.
  11. #9
    diamondgas's Avatar
    Newcastle Upon tyne
    6,050
    Actually the fact that a screwed fitting was under screed was my original concern ambrosia
  12. #10
    Jul 2012
    Swansea
    12
    Have you considered using track pipe?
  13. #11
    Mar 2012
    1,896
    Can you use trac pipe inside a school???
  14. #12
    1,399
    BS9891 has the info. for coverage, protection etc.
    You can use trac pipe anywhere if fitted to the standards.
  15. #13
    Mar 2012
    705
    Quote Originally Posted by hammers4spanner View Post
    what you mean??
    I thought with the fittings under the screed it would be completely wrong but that has been proved wrong
  16. #14
    1,399
    Screwed/threaded joints do not need to be accessible like compression. Just make sure joints are done properly and fully tested.
  17. #15
    Jul 2012
    Swansea
    12
    Just read through the G2 and it says that the Track Pipe can be buried in concrete floor just as normal pipe. (50mm bed with at least 25mm cover).
  1. Joints under screed, ok to do?
    By webby252 in forum Fittings & Pipes
    Last Post: 01-08-2012, 01:33 PM
  2. First fix pipes before screed
    By Sanke in forum Plumbing Forum
    Last Post: 13-02-2012, 05:31 PM
  3. putting pipe under screed
    By ambrosia in forum Gas Safe Register Forum - Public Forum
    Last Post: 13-10-2011, 11:32 PM
  4. access box in screed
    By 4candles in forum Central Heating Forum
    Last Post: 04-08-2009, 08:07 PM
  5. Laying pipes under screed floor
    By Drunkn Munky in forum Central Heating Forum
    Last Post: 21-07-2009, 03:25 PM
locatimg gas pipe under screed
screed pipe min cover
burying gas pipe screed depth
what pipe to use underscreed in new home
34 iron screed pipe
pipe in pipe minimum screed
installing gas pipe under screed
