Results 1 to 15 of 45
Plumbing & Plumbers Forum - Am thinking...plate heat exchanger gone blocked?
Discuss Am thinking...plate heat exchanger gone blocked? in the Gas Safe Register Forum - Public Forum at Plumbers Forums; Hi fellers, I have just had a call from a client who has a potterton performa 24. She says her hot water only gets warm and the boiler stops and ...-
19-07-2012 #1Plumbers Arms member
- Jun 2009
- Hampton court, Surrey
- 1,599
- Thanked 42 Times in 42 Posts
Hi fellers, I have just had a call from a client who has a potterton performa 24. She says her hot water only gets warm and the boiler stops and starts when in hot water mode. Its ok in the central heating mode.
So, I am thinking a blocked up heat exchanger. Now, is it worth me buying the heat exchanger before looking at the boiler and replacing? Or, should i check it out and test the stats?
Thanks guys
19-07-2012 #2Top Plumbing Forum Contributor
- Feb 2011
- 653
- Thanked 74 Times in 71 Posts
Re: Am thinking...plate heat exchanger gone blocked?
Check it out first, could be something silly, flow switch / transducer failing maybe?
The Following User Says Thank You to snowhead For This Useful Post:
Atouchofgas (19-07-2012)
19-07-2012 #3Plumbers Arms member
- 741
- 7
- Thanked 54 Times in 53 Posts
Check the ntc I've found these are good for going, also definatly worth taking the plated off and checking they are easy enough to get out.
19-07-2012 #4Plumbers Arms member
- Jun 2009
- 1,599
I think i shall just go without ordering the heat exchanger and take the one out and give it a wack to see if any scale falls out
19-07-2012 #5uɐɯ sɐƃ moderator
- Jan 2010
- maesteg,south wales
- 13,315
- 827
- Thanked 1,264 Times in 1,207 Posts
GASMAN
19-07-2012 #6Plumbers Arms member
- Jan 2011
- A, A
- 104
- 19
- Thanked 12 Times in 12 Posts
Snowman, what's a transducer?
Follow me on Twitter @ ignite_gas
19-07-2012 #7Plumbers Arms member
- Jun 2009
- 1,599
I did see a post on here a while back and the guy had the same problem. Someone told him to take the heat phex out and whack it a few times. He did and scale fell out and hey presto. All was fine
19-07-2012 #8Plumbers Arms member
- Jun 2009
- 1,599
Here is the link...http://www.ukplumbersforums.co.uk/ce...ma-28-a-2.html (hot water cutting out! performa 28)
This sounds exactly like the problem I have
19-07-2012 #9uɐɯ sɐƃ moderator
- Jan 2010
- 13,315
- 827
GASMAN
19-07-2012 #10Plumbers Arms member
- Jun 2009
- 1,599
All the guys who helped this guy have all but disappeared. Am sure there are a few I have wondered where they went. Where is unguided by the way?
19-07-2012 #11Plumbers Arms member
- Jun 2009
- 1,599
dumping into the central heating side Gasman? i am definitely not going to buy it. Does anyone buy their stuff from Euro Boiler Parts? If so, are they any good?
19-07-2012 #12uɐɯ sɐƃ moderator
- Jan 2010
- 13,315
- 827
GASMAN
19-07-2012 #13Plumbers Arms member
- Jun 2009
- 1,599
thanks gasman. I really need to find a decent spares supplier. Not many have the parts you need on the day you need them hey
19-07-2012 #14
21-07-2012 #15Plumbers Arms member
- Jul 2011
- Wales
- 783
- 11
- Thanked 57 Times in 55 Posts
Depends on the condition of the diverter valve, new ones will resist heat tracing through to the heating flow, where as an old diverter valve with worn springs and seals will allow heat to pass by if the PHEX is blocked.
The way I try and determine whether the PHEX is blocked, is where possible, feel the flow and return from the primary heat exchanger, if the flow is untouchable and the return is noticeably cooler, the PHEX is likely at fault.
I have on several occasions cleaned partially blocked PHEXs by removing them and blasting the primary ports back and forth with an outside tap. Quite satisfying when you see little black lumps flying out.
The Following User Says Thank You to R1CKY For This Useful Post:
zeebeedee (23-07-2012)
Plate heat exchanger
By Bennett in forum Plumbing ForumReplies: 17Last Post: 18-05-2012, 05:41 AM -
whats the best way clean a blocked plate heat exchanger
By julesverne in forum Gas Safe Register Forum - Public ForumReplies: 11Last Post: 29-12-2011, 02:25 PM -
domestic plate heat exchanger
By debsdew in forum Central Heating ForumReplies: 2Last Post: 05-01-2011, 09:15 PM -
blocked plate heat exchanger and sourse of black flakes
By emailalantaylor in forum Central Heating ForumReplies: 12Last Post: 19-12-2010, 08:50 PM
2Likes
Bad air lock in cold feed
1 Hour Ago in Plumbing Forum
