Plumbing & Plumbers Forum - Refiring Boiler
Refiring Boiler
Discuss Refiring Boiler in the Gas Safe Register Forum - Public Forum at Plumbers Forums; Hi If a property has been left empty and the central heating system has been drained down and the gas turned off at the ecv, can the system simply be ...-
17-07-2012 #1New to Plumbing Forum
- Mar 2011
- 18
- Thanked 1 Time in 1 Post
Refiring Boiler
Hi
If a property has been left empty and the central heating system has been drained down and the gas turned off at the ecv, can the system simply be refilled, the gas turned on and the boiler fired? Or does all the necassary gas checks need to be done?
Thanks in advance.
17-07-2012 #2UK Plumbersforums Trusted Advisor.
- Oct 2010
- Northampton
- 6,058
- 595
- Thanked 290 Times in 280 Posts
Re: Refiring Boiler
will advise to hire a gas safe register engineer to check it all
18-07-2012 #3Plumbers Arms member
- Nov 2010
- Tavistock. Devon
- 1,798
- 38
- Thanked 173 Times in 160 Posts
Re: Refiring Boiler
Would pay to call a GSR in, to check boiler etc ! you can refill system to save some time, dont forget to replace inhibitor !!
18-07-2012 #4UK Plumbersforums Trusted Advisor.
- Apr 2011
- Newcastle Upon tyne
- 6,053
- 299
- Thanked 770 Times in 744 Posts
Re: Refiring Boiler
If it's your own home you can do as you please, if it's tenanted property and you're the landlord then you have a duty of care and it'd be advisable to have a safety check carried out. In saying that it would be of benefit to yourself for your own piece of mind to have it all checked out regardless of occupancy by a pro
IMHO
18-07-2012 #5UK Plumbersforums Trusted Advisor.
- Dec 2010
- WestMidlands
- 5,831
- 124
Re: Refiring Boiler
best to get a gas safe engineer to re-commission/test the appliances.
were the appliances fitted correctly and working correctly when turned off? has anything happended during the period they have not been working which could effect there use/safety?Ammonia is found on Pluto, Jupiter and, in small amounts, on Uranus.
btw im commercial, NOT.
1Likes
gas explosion in notts
9 Minutes Ago in General Off-Topic Chat
