Results 1 to 15 of 24
Plumbing & Plumbers Forum - plastic coted pipe
Like Tree4Likes
plastic coted pipe
Discuss plastic coted pipe in the Gas Safe Register Forum - Public Forum at Plumbers Forums; just a quick question, a gas pipe has to be sleeved through a wall, we all know that, my question is can you put plastic coted pipe through a wall ...
    sav
    sav is offline
    Steady Plumbing Forum Contributor sav's Avatar
    Sep 2009
    125
    Default plastic coted pipe
    just a quick question, a gas pipe has to be sleeved through a wall, we all know that, my question is can you put plastic coted pipe through a wall as a sleeve insted of a bit of waste pipe with a bit of pipe in it?
    mountainman's Avatar
    Jan 2012
    Essex
    3,201
    Default
    No, even plastic coated pipe has to be sleeved.
  3. Proud to be 'Part P', the world is now my mollusc!
    tamz's Avatar
    Scotland
    9,363
    Default Re: plastic coted pipe
    You can't use ordinary plastic coated but you can if it is kuterlex plus (the one with the air channels)
    663
    It's to allow for movement of the pipe or wall.
    The plastic coating won't easily move on the pipe.
    Oct 2007
    696
    The sleeving should normally be made of the same material as the pipe.
    Beer is the reason I get up every afternoon.
    1,399
    Sleaving gas pipe through a wall is not just to protect the pipe from corrosion as plastic coating would accomplish. It is so that you can seal the inside wall end and if the pipe was to rupture for any reason you won't have gas leaking into a cavity.
    neily01 likes this.
    Gray0689's Avatar
    Jun 2010
    Northern Ireland
    4,667
    Default
    I asked that question from a instructor he said it was allowed as a sleeveing
    1,399
    Quote Originally Posted by Gray0689 View Post
    Plasitc coating is suitable for a 10mm supply pipe through the back of a builders opening to a fire.
    Not suitable for a gas pipe directly through a cavity wall. It must be sleaved!
    Gray0689's Avatar
    Jun 2010
    Northern Ireland
    4,667
    Default
    I'll wait for kirk to correct me if I'm wrong
    Jan 2012
    Essex
    3,201
    Default
    As Snowhead said, the sleeve is there to provide a movement gap between the wall and pipe as well as sealing any cavity.
    tamz's Avatar
    Scotland
    9,363
    Hence why kuterlex plus is suitable , but why would you. It is too expensive for everyday use.
  13. #12
    Jan 2012
    Essex
    3,201
    Default
    Quote Originally Posted by tamz View Post
    I thought the same, does that make me an honorary Scotsman?
  14. #13
    tamz's Avatar
    Scotland
    9,363
    Quote Originally Posted by mountainman View Post
    Lots of mountains up here for you
  15. #14
    Jan 2012
    Essex
    3,201
    Default
    Och! Nae problem.
    tamz likes this.
  16. #15
    1,399
    This is basic bread and butter stuff. Or so I thought. Gas pipe installation.
    You can use a number of materials, PVC, copper etc., as long as the gas pipe can pass though and be sealed on inside.
  1. Plastic pipe
    By Roastbeef in forum Plumbing Forum
    Last Post: 02-03-2012, 11:13 AM
  2. Plastic pipe verus copper pipe
    By mark_mc in forum Plumbing Forum
    Last Post: 06-07-2011, 11:15 AM
  3. plastic pipe
    By redface in forum Plumbing Forum
    Last Post: 16-04-2011, 09:13 PM
  4. Plastic Pipe
    By rolymo in forum Plumbing Forum
    Last Post: 14-10-2009, 09:39 PM
  5. Plastic pipe
    By Bernie2 in forum Plumbing Forum
    Last Post: 21-08-2009, 06:56 PM
gas safe pvc coated copper
tracpipe installation guide
should trac pipe be sleaved through a wall
