Results 1 to 12 of 12
Plumbing & Plumbers Forum - WB 28si boiler fault
Discuss WB 28si boiler fault in the Gas Safe Register Forum - Public Forum at Plumbers Forums; I was at a customer house tonite . The above boiler was givng a slow single light fault code on ch. When I reset it and turn on the heating ...-
02-07-2012 #1Plumbers Arms member
- Aug 2010
- 144
When I reset it and turn on the heating or hot water the boiler tries to light and actaully does light for 4-5 seconds then goes thru the same procedure 4 times then goes back to lockout.
I went thru the fault finding in the manual and this indicates a gas valve fault.
The same scenario as above happens with the combustion chamber off.
I am going to change he gas valve tomorrow. Any other suggestions.
have checked electrode they are correct and the inlet pressure is 19 mb
02-07-2012 #2UK Plumbersforums Trusted Advisor.
- Apr 2009
- Tunbridge Wells
- 5,137
- 531
- Thanked 427 Times in 362 Posts
Re: WB 28si boiler fault
Forget that. I am dum!
Gas, LPG, and OFTEC (oil) Registered.... visit my website at: www.prestigeplumbers.co.uk
Click to follow the link!
02-07-2012 #3UK Plumbersforums Trusted Advisor.
- Apr 2009
- Tunbridge Wells
- 5,137
- 531
You've checked the flame rectification?
You've checked the thermistors?Gas, LPG, and OFTEC (oil) Registered.... visit my website at: www.prestigeplumbers.co.uk
02-07-2012 #4UK Plumbersforums Trusted Advisor.
- Nov 2011
- Beautiful Barlick
- 5,361
- 291
- Thanked 378 Times in 372 Posts
this is open forum ????
>>>>>>>>>>GSR? Want gas safety or boiler repair advice? We will check out that you're genuine via the gas safe website, so please dont be offended when we ask for your details. DIYers, odd job people and have a go heroes need not apply
I'M DANCIN, YOU ASKIN ?
02-07-2012 #5UK Plumbersforums Trusted Advisor.
- Apr 2009
- Tunbridge Wells
- 5,137
- 531
I don't know anymore. I'm just confused. Part of the gas section is open and part isn't (apparently).
I'm not sure if we're in the locked out part or not. It should all be blanket locked out to joe public. We had this a couple of days ago!Gas, LPG, and OFTEC (oil) Registered.... visit my website at: www.prestigeplumbers.co.uk
02-07-2012 #6UK Plumbersforums Trusted Advisor.
- Apr 2009
- Tunbridge Wells
- 5,137
- 531
No we have the Gas Safe forum and the Gas Safe Registered forum.
Latter one is for registered engineers only. Confusing.Gas, LPG, and OFTEC (oil) Registered.... visit my website at: www.prestigeplumbers.co.uk
02-07-2012 #7UK Plumbersforums Trusted Advisor.
- Nov 2011
- Beautiful Barlick
- 5,361
- 291
this part is open danny, its the gas safety registered plumbers section that isnt :-)
The Following User Says Thank You to dancinplumba For This Useful Post:
Dannypipe (02-07-2012)
02-07-2012 #8UK Plumbersforums Trusted Advisor.
- Apr 2009
- Tunbridge Wells
- 5,137
- 531
Yeah, I've been told that before but thanks mate. I'm a bit slow off the mark tonight.
02-07-2012 #9UK Plumbersforums Trusted Advisor.
- Nov 2011
- Beautiful Barlick
- 5,361
- 291
soz danny :-)
02-07-2012 #10UK Plumbersforums Trusted Advisor.
- Apr 2009
- Tunbridge Wells
- 5,137
- 531
I'm just not going to answer gas questions until it's all registered people only as I'll keep doing this accidently.
02-07-2012 #11UK Plumbersforums Trusted Advisor.
- Apr 2009
- Tunbridge Wells
- 5,137
- 531
09-07-2012 #12Top Plumbing Forum Contributor
- Aug 2011
- Wolverhampton
- 699
- Thanked 48 Times in 46 Posts
Check your gas valve resistance and if they're right (the one should be double the other, about 180/360 ohms IIRC) then give Worcester a call and get them to give you the factory setting adjust for the gas valve. Could be that on minimum fan speed there isn't enough gas passing through to keep alight. You'll obviously need your FGA and the correct CO2 figures as well.
You might also want to check the negative fan pressure to see if it needs servicing, then check the flame probe, which if the boiler is older may be the problem. You might need to get a new seal before doing this though.
honeywell 927 and combi boiler worcester 28si (2) (british gas C1)
By awariat in forum Central Heating ForumReplies: 4Last Post: 19-02-2012, 01:26 PM -
By awariat in forum I'm looking for a Plumber or Gas EngineerReplies: 3Last Post: 18-02-2012, 09:16 PM -
British Gas C1 / Worcester 28si - Strange fault...
By AKN in forum Central Heating ForumReplies: 14Last Post: 06-11-2011, 12:21 PM -
Worcester Bosh Boiler 28SI II Fault Indicator Light
By rachelspencer in forum Central Heating ForumReplies: 7Last Post: 17-11-2010, 10:17 PM -
Worcester 28si ii Boiler
By Bertie in forum Plumbing ForumReplies: 1Last Post: 19-03-2009, 07:31 PM
2Likes
Cost to remove old electric...
8 Minutes Ago in Plumbing Forum
