Page 2 of 2 FirstFirst 12
Results 16 to 25 of 25
Plumbing & Plumbers Forum - who can legally move gas meter supplies ?
Discuss who can legally move gas meter supplies ? in the Gas Safe Register Forum - Public Forum at Plumbers Forums; Syty, do you not have to have the permission of the gas board before you can do any of that work?...
  1. #16
    SimonJohns's Avatar
    Bridgend, Wales
    3,609
    Default
  2. "nothing is impossible"
  3. #17
    Plumbing Forum Contributor
    London
    72
    Default Re: who can legally move gas meter supplies ?
    If you plan to move one than yes, you need permission.
  4. #18
    To alter or move a gas service supply you need to have a GD1 main layer and service ticket.I worked with national grid for 8 years as an ESE and any supply attached to national grid pipework ( 90% is owned by national grid) you can only go through them to resite service,sorry but they have you over a barrel on this one
  5. #19
    Super Plumbing Forum Contributor on31ll's Avatar
    Apr 2012
    Mogadishu
    1,947
    Can i ask what ESE means ? Sorry ! Am i correct in guessing like a tender ?
  6. #20
    Quote Originally Posted by on31ll View Post
    No ESE Emergency Service Engineer, I was on contract with National Grid to do emergency, and work upstream of the meter
  7. #21
    Apr 2012
    Mogadishu
    1,947
    ahh ok ! learn somthing new everyday ! thanks
  8. #22
    Jun 2011
    Surrey
    15
    BES sell the parts as they can be used to run underground outlets by a certified engineer.
    The primary meter can only be moved by a qualified person who is certified/liscensed by the HSE this is usually the local gas emergency service providers (ESP) e.g National Grid Gas, Southern Gas Networks etc.
    There are some 3rd party companies who are licsensed to carry out this work which they ususally do on iPGT (independent gas transportion) site's. This is a site where the mains gas and service pipes are owned by a different company to the local ESP. You would need to contact the ESP to move the meter or find out an approved contractor.
    It may look simple but I've seen people use the wrong size fittings between metric and imperial PE and cut into steel only to find it's been sleeved with plastic. Then they panic and call the ESP or are too stupid and wrap and leave a leak and fill a house with gas, NOT GOOD!! Hope that helps with your query.
  9. #23
    Jun 2011
    106
    as a gsr engineer you are legally qualified to remove existing meter and put same meter back on in same place, ( so you can work on gas pipe )
    legally you cannot replace existing meter for a new one in the same location or move the meter
  10. #24
    Jun 2011
    Surrey
    15
    Sorry I wasn't clear with the way I worded my response, as a gsr engineer with MET1 you are qualified to take out and refit the meter. I should have said 'meter position' as in the gas service pipe that is fed from the gas main as the main query was about MDPE and who can legally move gas meters. Then it is a qualified person who is approved by the HSE, most of who work for the ESP or one of their contractors, and not a gsr engineer. Hope that's a little clearer.
  11. #25
    Aug 2011
    West Midlands
    25
    To Alter the Inconing Service Pipe a GIRS Registered UIP can undertake this work, See lloyds Registration Website this Allow the GIRS -UIP to Inform the DNO /Transporter = NGT,WalesWest,Northern Gas Networks Scotia Networks & Southern Gas Networks.Ten+ Years ago OFGEM made Transco /-now NGT was made to sell off the 5 LDZ Networks as above, ( NGT Kept the Most Densley Populated LDZ's -Nort West,West Mids East Mids East Anglia North London as these made more profit ) Due to the Monopoly Commission. Also This Allowed New Compatition in Connections Allowing IGT -to offer connection & metering services.However you will find that the gas shippers rent the meter from a MaM or Mop. to which the MaMs & MoPs undertake the metering siteworks Inn house Engineers (or to ever provides the biggest brown envolope-so im informed) Metering Service Companies ,who have to be a Ofgem OAMI Registered Company ( Ofgem Approved Meter Installer ) CoP1a= Domestic Metering CoP1b=Non-Domestic Metering- CoP1c Industrial Metering .+ Gas Safe Registered --
    If a GSR Met1,Qualified engineer needed a Meter Re-Site they would need to have the MaM/MoP writtern permission before you can Legally touch their Meter Asset & a GSR Eng. will need a OAMI registered company to Inspect the works on behalf of the MaM/MoP-This will just cost more dollars this way ,So as most MaMs /MoPs are also OAMI Registered to.....
    Meterman1
  1. Gas Meter move
    By donnybarr in forum Plumbing Forum
    Last Post: 01-10-2012, 05:46 PM
  2. Where does a company stand legally?
    By markhunnisett in forum Plumbing Forum
    Last Post: 19-08-2011, 12:25 AM
  3. Can I legally Sign Off Boiler Installers
    By gasleak in forum Gas Safe Register Forum - Public Forum
    Last Post: 30-06-2011, 09:47 PM
  4. can a gas safe engineer move a gas meter
    By jonesy76 in forum Plumbing Forum
    Last Post: 15-02-2011, 09:18 AM
  5. Move or not to move Boiler?
    By craig in forum New Member Introductions
    Last Post: 26-08-2010, 01:57 AM
who can move a gas meter
moving gas meter
move gas meter
who can legally move a gas meterwho can move gas meterwho can move gas metersplumbing moving gas meter
