Results 1 to 15 of 22
Plumbing & Plumbers Forum - prv discharge pipe
prv discharge pipe
Discuss prv discharge pipe in the Gas Safe Register Forum - Public Forum at Plumbers Forums; been to quote a job today and its going to be a right mere to run the prv pipe to outside can you discharge it internally into a soil stack ...
    Mar 2011
    85
    Default prv discharge pipe
    been to quote a job today and its going to be a right mere to run the prv pipe to outside can you discharge it internally into a soil stack if you have a tundish ?
    Mar 2012
    brizzle - the mild mild west
    225
    Default Re: prv discharge pipe
    i have seen it done to a little tank with a lid in the bottom of the airing cupboard - done by a big firm, and apparently they reckoned they had approval to do this. anyone else come across this?
    Simon F's Avatar
    Nottingham
    1,430
    AWheating's Avatar
    WestMidlands
    5,839
    its possible. Its done in alot of flats and basement installations. You may require building control permission.
    btw im commercial,
    NOT.
    SimonJohns's Avatar
    Bridgend, Wales
    3,609
    Default
    I know it can be done on uvhws. But for a boiler I'm sure you have to go outside
    "nothing is impossible"
    Mar 2012
    1,905
    have worked on site a block of flats where each flat had a worcester gs 24 junior combi and everyone had tundish then into hepvo trap then onto soil stack , all passed by build control.
    Feb 2009
    chesterfield
    849
    or you could try these Condensate Pumps: NXT Gen: VCMA
    Feb 2009
    chesterfield
    849
    sorry i think ive just totally misread the op, i was thinking condensate, worth a look for condensate stuff tho.
    AWheating's Avatar
    WestMidlands
    5,839
    you can get a combined condense blow off pump but they cost around 180 squids.
    btw im commercial,
    NOT.
    Feb 2009
    chesterfield
    849
    have you got a link to that??
    Mar 2012
    1,905
    personally would rather find another way instead of possibly pricing myself out with an extra £180
    Feb 2009
    chesterfield
    849
    and how does the condensate combine with the blow off, with condensate being acidic, i.e what type of pipe is it run through?
  13. #13
    AWheating's Avatar
    WestMidlands
    5,839
    there a few about. Baxi have even got there own branded one on the market now also.
    Baxi Multifit External Boiler Discharge Pump - | Plumb Traders
    btw im commercial,
    NOT.
  14. #14
    AWheating's Avatar
    WestMidlands
    5,839
    Quote Originally Posted by andyg0507 View Post
    one copper pipe into pump, one plastic im guessing.
    btw im commercial,
    NOT.
  15. #15
    kirkgas's Avatar
    Dec 2009
    Coatbridge, Lanarkshire
    3,515
    condensate requires non metallic, blow off requires pipe capable of taking high temp, so its just about choosing the right type of plastic to suit the blow off temp
  1. Unvented cylinder discharge pipe
    By Gromit in forum Central Heating Forum
    Last Post: 24-09-2012, 09:53 PM
  2. Saniflo discharge pipe question
    By greasemonkey in forum Sanitary Ware
    Last Post: 20-02-2012, 09:32 PM
  3. saniplus discharge pipe?
    By supared1 in forum Plumbing Forum
    Last Post: 16-02-2012, 07:21 PM
  4. where to fit saniflo discharge pipe
    By gravytrain in forum Plumbing Forum
    Last Post: 16-02-2012, 01:57 PM
  5. discharge pipe work from combi
    By desrob in forum Central Heating Forum
    Last Post: 31-07-2011, 08:55 PM
p.r.v. discharge pipe
prv pipe
prv discharge pipe
PRV to soil stackprv doscharge pipe covergas safe prv pipeprv into a soil stack
