Plumbing & Plumbers Forum - vokera linea 24 problem!
Discuss vokera linea 24 problem! in the Gas Safe Register Forum - Public Forum at Plumbers Forums; having a problem with a customers vokera, complaits about heating cutting off at random times, having to reset etc. replaced the dhw and heating thermisters worked a treat for 4 ...-
26-03-2012 #1New to Plumbing Forum
- Jun 2011
- bournemouth
- 7
having a problem with a customers vokera, complaits about heating cutting off at random times, having to reset etc. replaced the dhw and heating thermisters worked a treat for 4 days now its gone back to its good old self!
done the basic checks pump running fine firing properly etc.
most awkward boiler to work on to date.
any help will b appreciated.
cheers.
27-03-2012 #2Plumbers Arms member
- May 2009
- 7,303
- 218
Re: vokera linea 24 problem!
What fault code comes up when they have to reset it,possible common fault is the ignition board attached to gas valve in plastic housing
imho
27-03-2012 #3UK Plumbersforums Trusted Advisor.
- Apr 2011
- Newcastle Upon tyne
- 6,050
- 299
- Thanked 769 Times in 743 Posts
common intermittent fault is the ignition pcb as puddle says
28-03-2012 #4New to Plumbing Forum
- Jun 2011
- bournemouth
- 7
cheers guys! i willl let you no how i get on!
28-03-2012 #5Plumbers Arms member
- Oct 2010
- 1,654
- Thanked 81 Times in 81 Posts
Good luck
ye cannot beat a good intermittent fault , Do your head in lolLast edited by Puddle; 28-03-2012 at 11:13 PM.
03-04-2012 #6Plumbing Forum Contributor
- Nov 2010
- Yorkshire
- 46
- Thanked 3 Times in 3 Posts
i had the same fault and if i remeber correctly it was the venturi that had a spiders web in! it would intermittently lock out
04-04-2012 #7Plumbers Arms member
- Oct 2010
- 1,654
I have had similar and that did the trick well happy
Vokera Linea 24 Boiler Issue, Advice Required Homeserve problem
By PlumbPunter in forum Central Heating ForumReplies: 8Last Post: 02-02-2012, 09:15 PM -
vokera linea 28
By vectra65 in forum Central Heating ForumReplies: 5Last Post: 02-12-2011, 06:07 PM -
vokera linea 24
By genisis in forum Central Heating ForumReplies: 7Last Post: 08-01-2011, 04:06 PM -
anyone seen the new vokera linea one
By plumbster3456 in forum Central Heating ForumReplies: 0Last Post: 05-12-2010, 10:00 AM
Smells - please please please...
