Results 1 to 15 of 18
Plumbing & Plumbers Forum - Quoting Jobs - Powerflush/Service
Like Tree2Likes
Discuss Quoting Jobs - Powerflush/Service in the Gas Safe Register Forum - Public Forum at Plumbers Forums; Hi, I'm just setting up so got loads of questions. Lets say I get a call for a powerflush, would you go round and take a look or just send ...
    Jan 2012
    179
    Default Quoting Jobs - Powerflush/Service
    Lets say I get a call for a powerflush, would you go round and take a look or just send out a quote? Same with a service?
    By going to look at least you have got an idea of the system etc, but would seem a waste of time to go look at a system just to go back and powerflush it?
    What do you guys do?
    Roger Welton's Avatar
    Dec 2011
    Somerset
    1,744
    Default
    I always like to go out and have a look, just in case there are any gremlins lurking, or the customer has misdiagnosed the problem.
  3. GSR? Want gas safety or boiler repair advice? We will check out that you're genuine via the gas safe website, so please dont be offended when we ask for your details. DIYers, odd job people and have a go heroes need not apply.
    Read more: http://www.ukplumbersforums.co.uk/pl...#ixzz2AdEwjWbf
    Jan 2012
    179
    Default Re: Quoting Jobs - Powerflush/Service
    Quote Originally Posted by Roger Welton View Post
    Ok thanks, lets say for instance you go to quote for a service on the boiler but you see something like black staining around the fire (at the quoting stage), what would you do? By metioning it you could be seen to be asking for more work (and money) by saying the fire also needs a service and if it doesn't pass a spillage test will be capped off.
    Dec 2011
    Somerset
    1,744
    Default
    Sorry servicing is fixed cost for me, as always duty of care checks required on other appliances. Any additional work is obviously at extra cost (oh it just stopped working this morning!)
    Always go to quote for powerflush, or any other work.
    benfisher's Avatar
    Mar 2011
    60
    I'm with roger on this, just make sure when you tell them your fixed price for servicing that the price is for a the service only and any parts required will be an extra charge on top of the service cost. As for the powerflushing always go have a look especially if BG have recommended it
    Jun 2010
    698
    You need to survey a powerflush, as the pipework could be the cause & needs sorting, seen lots of old dhw gravity systems changed to fully pumped with the open vent & cold feed left on the F & R on the cylinder!!
    If the client doesn't want it altering, makesure you put your recommendation in writing to cover yourself.
    I service appliances on a fixed cost, plus parts, but if it's a new customer when quoting the price I state 'it's for a straight forward service' as lots of newbies have a problem as well, & if they get the repair done at the sametime it's not fair to the regular servicing customers.
    If the newbies do have a problem I visit them asap repair it & then arrange a service visit, or if it makes sense as your doing the repair, service it but charge extra.
    What ever you do makesure you contact them in 12 months time for the next service, you'll get alot of loyal customers this way & find out which ones are worth rushing to.
    1,363
    Half the time people call me up and ask for a powerflush, it isnt needed. Last time I got a call, BG had been there previously and said it needed a flush due to banging/vibrating. Turns out the TRV's were single direction and on the wrong way round.
    You cant go and look at a service before doing it, its not a cost effective way of spending your time. A service will be a set price and you will soon learn which boilers will often need gasket kits, other bits and pieces etc etc. Just make sure you state your price you say if it needs any gaskets etc there will be an additional charge,
    Mar 2012
    1,883
    I think the bigger question is are you doing a service or a safety check???Most gas companies now just do a safety check but blagg it as a service or some i know lift the cover off blow the cobwebs off re-instate cover and charge a service !!
    Dec 2011
    Somerset
    1,744
    Quote Originally Posted by hammers4spanner View Post
    Judging by the state of most boilers I see this happens all too often!
    Jan 2012
    179
    I know a company that does this safety check but calls it a "service". Not saying anymore though.
    When I do a service it will be a proper service, no cutting corners. If it needs striping and cleaning thats what I'll do.
    bennygas likes this.
    dancinplumba's Avatar
    Beautiful Barlick
    5,361
    Quote Originally Posted by rodders View Post
    does it have a G in it's name ?
    >>>>>>>>>> I'M DANCIN, YOU ASKIN ? <<<<<<<<<<
  13. #12
    Oct 2009
    19
    Hi guys, just a quick one on the servicing, would you get the gasket for a boiler before you go to the job, or do you keep them as van stock.
  14. #13
    Dec 2011
    Somerset
    1,744
    Default
    I keep Worcester, Vaillant, Remeha and Keston on the van
  15. The Following User Says Thank You to Roger Welton For This Useful Post:
    gas frank (27-03-2012)
  16. #14
    Jan 2012
    179
    Quote Originally Posted by gas frank View Post
    To start with I will get them as I need them but then start to keep as stock as soon as work picks up a bit for me.
  17. #15
    Jun 2010
    698
    I keep all the gaskets that are common to our area, baxi, wb, remeha, gw & vaillent
  1. Touching things while quoting/ while 'not on the clock.'
    Last Post: 09-11-2011, 09:52 PM
  2. Quoting For Jobs......
    By blayedrunner in forum Plumbing Forum
    Last Post: 18-06-2011, 12:37 AM
  3. quoting
    By MikeAFCB in forum Plumbing Forum
    Last Post: 26-05-2011, 08:23 PM
  4. Quoting jobs
    By NellyC in forum Central Heating Forum
    Last Post: 27-05-2010, 08:05 PM
anton powerflush
