Page 5 of 5 FirstFirst ... 2345
Results 49 to 56 of 56
Plumbing & Plumbers Forum - Can you work on a boiler if your not Gas Safe?
Like Tree22Likes
Discuss Can you work on a boiler if your not Gas Safe? at UK Plumbers Forums; Originally Posted by Clanger kay-jay, my response to your post was a bit confusing. The point I wished to make, was that ACS assessment is not a reliable test of ...
  1. #49
    2,037
    Default Re: Can you work on a boiler if your not Gas Safe?
    Quote Originally Posted by Clanger View Post
    The point I wished to make, was that ACS assessment is not a reliable test of competence.
    But, we just bow our heads and accept it. We might think that GSR leads to more work and better professional status - it doesn't. We will reflect on the first two decades of the 21st century as 'the great train-ing robbery'. With no one to represent our interests, the self employed are exposed to as much tax, as the CO lobby, HSE, GSR, Government etc, want to load on us.
    I kind of disagree with your comment on ACS.
    What in your opinion would be a reliable test of competence?
    To pass the ACS you must have some form of training/knowledge in Gas regulations & works. You must then put this training/knowledge to use and for they few days work safely.
    At the very least you should take away with you the basic knowledge on how you should be working safely with gas. Wither you use that in your everyday work environment is another matter.
    We then have to go through it again in 5 years time where any bad habits or complacency's should be addressed and again you should leave with the basic knowledge of safe working.
    Passing a 45 minute driving test does not mean you are are suddenly Lewis Hamilton. What it does (or should) mean is, you have at the very least the basic skill-set/knowledge to drive safely, unsupervised on public roads and have been approved to apply for a license to do so. Just like the ACS qualification.
    The ACS is not a complete package. It basically confirms that Joe Bloggs has the basic knowledge and skills to work with gas safely.
    I did say "I kind of disagree with your comment". What I would like to see is a bit more time spent on various fires as I believe there is a lack of knowledge out-there from supposedly qualified engineers. Maybe this is due to a lot of engineers do not work on them often enough.
    Just my tuppence worth.
  2. #50
    2,037
    Quote Originally Posted by secret squirrel View Post
    You wouldn't doing too bad with that really, you need more qualifications to enter vet school than to be a medical doctor! it is harder to get into vet school than dr school.
    I've got a stanley knife, a makita and a head torch...... I may be able to assist.
    Just make sure you have a sterile surgical steel blade in that Stanley.
  3. #51
    Jul 2011
    442
    Quote Originally Posted by GrahamM View Post
    No problems with your well-made points Graham. But I can offer a better, more valid way of assessing competence, and its been used since we were hunter gatherers.
    Its called clinical observation. If I wished to have an adequate understanding of your competence, I would not invite you to a training centre.
    I would want to observe your performance in different work contexts. I could assess your 'know how', knowledge and performance without saying a word to you. It would take a couple of days at the most.
    If I wished to accertain your understandings of abstract (written) knowledge, I could verbally question you, while you are working - but this knowledge often has limited use in work situations for most technicians.
    I could offer more technical faults with competency and competence, with regard to what they mean and how they are defined, but I know one thing for sure - the current system does not test understanding, or knowledge or performance because they are tested in simulated environments - so they immediately contradict any sort of claim to 'competence' because this can only be tested in real situations - would we be happy with surgeon working on our families, that have only practised on dummies - I doubt it. Would we be happy flying with pilots that had only learned on simulators...probably not.
    It has become a belief that we can be trained in these situations, but really we only start learning on the job...we all know this for sure. So apprenticeship is the most reliable system - all other routes are a short-cut to this, and hence questionable as to their reliability and validity.
    This is a well documented area of discussion, and the Germans don't buy it - that is almost good enough for me!
    diamondgas and chris watkins like this.
  4. #52
    Jan 2017
    What about bleeding the pump in a combi boiler? Removing the brass plug and turning the rotor with a screwdriver then replacing the plug? Is that legal or do I need to be Gas Safe registered to do that?
  5. #53
    Norfolk
    3,000
    As long as you don't break into the gas way. Its then not gas work. Question is? why do you mess about heating systems if your not proven competent to do so.
  6. #54
    Norfolk
    3,000
    Question is? why are you messing around a boiler that you have not been proven competent in an assessment centre and are not legally registered to do so. Finer detail is if you have not broken into a gas way then that is not illegal.
  7. #55
    Jan 2017
    By training I am a car mechanic and I understand mechanical things like the mechanical parts of a boiler. Cars are arguably more dangerous than boilers. They have killed millions of people and you don't need to be certificated to work on them. If a pump sticks I free it up.
  8. #56
    Forum Thug
    croppie's Avatar
    23,832
    Removing the case constitutes gas work as it invariably forms part of the combustion seal.
    So, to put it bluntly, no you cannot. This is in accordance with section 26(9) with the Gas Safety (Installation and Use) Regulations.
    Irregardless of you being a mechanic and your trade kills more than ours.
    If there's something wrong with your boiler I suggest you call in a gsr.
    Croppie
    (By the way, I'm commercial!)
  1. Where's the best place to get gas safe work wear?
    By mylocalplumber in forum Plumbing Forum
    Last Post: 14-07-2013, 09:53 PM
  2. Replies: 62
    Last Post: 29-01-2013, 10:20 PM
  3. gas safe number and work outside of work!!
    By beesley121 in forum Gas Safe Register Forum - Public Forum
    Last Post: 28-01-2013, 11:23 PM
  4. D.I.Y Gas Work!!Calling All GAS SAFE ENGINEERS!!!!!
    By Hardy1 in forum Gas Safe Register Forum - Public Forum
    Last Post: 15-03-2012, 11:04 AM
  5. Looking to work with gas safe plumber
    By lee17 in forum Looking for work.
    Last Post: 29-02-2012, 04:23 PM
  6. Professional Plumber Required Looking to work with gas safe plumber
    Last Post: 09-01-2012, 06:16 PM
  7. work from gas safe site
    By Puddle in forum Gas Safe Register Forum - Public Forum
    Last Post: 29-05-2010, 08:39 AM
  8. Looking for work - Gas safe registered.
    By keepittight in forum General Off-Topic Chat
    Last Post: 27-01-2010, 09:21 PM
  9. YORK Controls
    By NickyTesla in forum Central Heating Forum
    Last Post: 07-10-2007, 08:19 PM
can i fix my own boiler
can a plumber fix a boiler
is it illegal to fix your own boiler
do plumbers fix boilers
can i repair my own boiler
