Results 1 to 12 of 12
Plumbing & Plumbers Forum - safe gas card
safe gas card
Discuss safe gas card in the Gas Safe Register Forum - Public Forum at Plumbers Forums; Hi can a gas safe card holder with out METER on there card work on boilers cookers fires heaters pipework ? Or on the other hand a gas safe card ...-
18-05-2009 #1Top Plumbing Forum Contributor
- Apr 2009
- 306
safe gas card
Or on the other hand a gas safe card holder who only has METER work on
surely these must all be taken at the same time
or you need two plumbers
18-05-2009 #2Plumbing Forum Contributor
- Apr 2009
- 68
Re: safe gas card
Yes, no, yes and yes. You can only work on appliances that you are qualified for and downstream pipework i.e. core ACS + modules, pipework only if thats all your qualified for and meters only if thats all your qualified for.
If you look on the back of the Gas Safe operatives card it will list appliances they can work on - if it's not on there then they can't do it .You don't have to do everything at same time - I haven't got a meter or warm air ticket but if I wanted to I could do the assessments and upon passing I'm sure my card would be updated to show this.
18-05-2009 #3Super Plumbing Forum Contributor
- Dec 2008
- 1,109
- Thanked 1 Time in 1 Post
Re: safe gas card
the problem being if you are soldering a gas pipe meter has to be isolated so you would need met1 theoretically
18-05-2009 #4Top Plumbing Forum Contributor
- Apr 2009
- 306
Re: safe gas card
Hi so jonathanb don't have METER, so how do you do a sound test?
or connect to gas meter and test???
18-05-2009 #5Plumbing Forum Contributor
- Apr 2009
- 68
Re: safe gas card
I'm allowed to - I can work downstream of the meter but not upstream, so can cap meter and work away.
Of course after disconnecting installation pipework from meter and using a temporary continuity bond ! Sorry guys am I missing the point here?Last edited by jonathanb; 18-05-2009 at 05:56 PM. Reason: Automerged Doublepost
18-05-2009 #6UK Plumbersforums Trusted Advisor.
- Hastings
- 4,015
- 47
- Thanked 404 Times in 374 Posts
Re: safe gas card
You only need the meter qualification to exchange or move meters. Core gas safety is sufficient for disconnecting, reconnecting, and tightness testing.
Mike
18-05-2009 #7Plumbing Forum Contributor
- Apr 2009
- 68
Re: safe gas card
Thanks for putting it simply Mike - thats the point I was trying to get across.
18-05-2009 #8Plumbing Forum Contributor
- Sep 2008
- uk
- 94
19-05-2009 #9Plumbing Forum Contributor
- Apr 2009
- 68
Re: safe gas card
Indeed he is!
29-05-2009 #10Top Plumbing Forum Contributor
- Apr 2009
- 306
Re: safe gas card
thanks for this and that more rule items
29-05-2009 #11Super Plumbing Forum Contributor
- Feb 2009
- Liverpool
- 1,972
Re: safe gas card
What a "fol-de-roll", perhaps if they went back to testing for "gas fitting" knowledge with everything in one module, we would be better off.
But would it be too expensive done that way?
As far as I am concerned I feel they could do it easily enough, there does not seem to be all that much in each module. Am I only saying that because I have been doing it for years? I don't know.
I suppose though people may baulk at having to be tested on things they are not going to use.
I often wonder though at some hundreds of pounds a module, could not the price of training and testing be brought down?
Anyway who chose the testing price structure anyway?
The colleges not the market, that seems a bit unfair.
What we need is an operative and self employed champion, who would ask the colleges about it, at the moment we just have to pay whatever is asked or perhaps be put out of work.
Perhaps if we reversed the roles a bit and formed into training and testing groups then asked the colleges what price they charged for block bulk training?
Lets hope the GasSafe scheme changes things. I feel it might, for by inspecting work done, instead of relying on certification under ideal conditions, it usually gives a good idea of what a person can or can not do.
And lets be honest that is all a compliance module usually consists of.Last edited by Bernie2; 29-05-2009 at 09:35 AM.
29-05-2009 #12Top Plumbing Forum Contributor
- Apr 2009
- 306
Re: safe gas card
And lets be honest
that's a good word
FOR new plums they need training,,plus gas safe.
For people in the trade for 20 years or so should only need gas safe for what it is.
like it was in 1996 they come to your house ,then go to your job with or with you.
Photo ID Gas Safe Register
By Rydell in forum Gas Safe Register Forum - Public ForumReplies: 14Last Post: 30-09-2010, 11:45 AM -
gas safe
By stevetheplumber in forum Gas Safe Register Forum - Public ForumReplies: 23Last Post: 12-05-2009, 09:53 PM -
New registration on Gas Safe
By chrisplumb in forum Gas Safe Register Forum - Public ForumReplies: 18Last Post: 08-05-2009, 09:29 AM -
Gas Safe Registration of Appliances
By Rydell in forum Gas Safe Register Forum - Public ForumReplies: 7Last Post: 19-04-2009, 11:45 AM -
Gas Safe for Eternity
By grahamep in forum Gas Safe Register Forum - Public ForumReplies: 3Last Post: 29-03-2009, 04:31 PM
www.ourworker.com
56 Minutes Ago in Plumbing Forum
