Results 1 to 9 of 9
Plumbing & Plumbers Forum - Halstead Ace Boiler Lockout
  • 1 Post By APPlumbing
Discuss Halstead Ace Boiler Lockout in the Gas Safe Register Forum - Public Forum at Plumbers Forums; Hi I was wondering if anybody could help with my query. We have a Halstead Ace boiler - that locks out everytime its due to start on timer. Once I ...
    Jan 2012
    Default Halstead Ace Boiler Lockout
    Hi
    Once I manually reset - it then starts ok.
    Then the central heating works great - but the hot water goes hot for 20 secs - then freezing - then hot again for 20 sec etc...
    Its a nightmare trying to shower etc.
    Hoping (infact praying) it does'nt need replacing and is a simple fix.
    Any advice is really appreciated.
    Cheers
    Gareth
    SimonJohns's Avatar
    Bridgend, Wales
    3,609
    Default Re: Halstead Ace Boiler Lockout
    not a diy fix, but wont take a gsr long to do
    if you post your location one of us maybe able to pop around an help
    Jan 2012
    Thanks for the reply.
    Were based up in Rotherham.
    You wouldnt happen to know - how much roughly the costs would be?
    Cheers
    Gaz
    diamondgas's Avatar
    Newcastle Upon tyne
    6,052
    Gareth,
    Crapy boiler unfortunatly . *sigh* ... and tends to be installed by the 'less-reputable-crew'...! However if you're lucky its something relatively simple regarding ignition recognition Doubt it though as you mention hot water temp fluctuation!
    Sometimes buying cheap or inheriting cheap is costly therafter .......... alas!!! SOZZ!
    Jan 2012
    thanks mate
    diamondgas's Avatar
    Newcastle Upon tyne
    6,052
    Quote Originally Posted by gazza123 View Post
    thanks mate
    You're welcome
    Honestly depends on variables as to how well any boiler will perform ... fact that yours locks out on start up tends to point to ignition recognition ... that can be relatively cheap! but there are a a good few other possibilities that can bring about the symptoms you describe ! Best bet would be to get someone in you know or stump for one of the 'fixed rate' buisnesses out here
    Mar 2013
    I also have a halstead boiler lockout. When it is cold and switched back on or occasiinally on hot water demand.
    I have replaced fan, pcb and checked all connections.
    Any suggestions please?
    Regards
    jay
    leicester
    APPlumbing's Avatar
    Locks Heath fareham
    3,177
    Quote Originally Posted by Jaywaden View Post
    I also have a halstead boiler lockout. When it is cold and switched back on or occasiinally on hot water demand.I have replaced fan, pcb and checked all connections.Any suggestions please?Regardsjayleicester
    Get a gas safe registered engineer in. We can not and will not give advice on boiler repairs on the open forum. Put a post in the looking for a plumber section of the forum.
    croppie likes this.
  9. The Following User Says Thank You to APPlumbing For This Useful Post:
    croppie (21-03-2013)
    croppie's Avatar
    Portadown, United Kingdom
    7,667
    Good advice given, please take heed.
    Please go to Gas Safe Register | Ensure your gas engineer is registered. or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location. I'm looking for a Plumber or Gas Engineer
    If you are gsr please increase your post count to 10+ then send a pm to either Gas man or Redsaw who will then check you and then give you access to the gsr private forum.
    Thank you.
    http://www.ukplumbersforums.co.uk/ce...ed-advice.html (notice gas safety related advice)
    Croppie
    (By the way, I'm commercial!)
  1. Halstead ACE HE 30 overheat lockout issue?...
    By FlowolF in forum Central Heating Forum
    Last Post: 25-01-2012, 10:15 AM
  2. Boiler lockout
    By fabien in forum Central Heating Forum
    Last Post: 30-12-2011, 07:40 PM
  3. Halstead Ace Boiler gone into Lockout
    By Nicola G in forum Central Heating Forum
    Last Post: 28-07-2011, 02:35 PM
  4. Halstead Finest Gold Lockout
    By TimP in forum Central Heating Forum
    Last Post: 15-04-2011, 12:08 PM
  5. Halstead Ace High Lockout
    By peterx666 in forum Central Heating Forum
    Last Post: 23-08-2010, 11:21 PM
halstead ace boiler lockout
halstead boiler ignition lockout
halstead boilers lockouthalstead ignition lockouthalsted boiler lock outhalstead ace boiler lock out
