Results 1 to 4 of 4
Plumbing & Plumbers Forum - potterton puma 80
potterton puma 80
Discuss potterton puma 80 in the Gas Safe Register Forum - Public Forum at Plumbers Forums; been call out to this boiler a few time now everytime i get there it works fine lady says it only seems to lockout first thing on a morning when ...-
12-12-2011 #1Plumbers Arms member
- Dec 2010
- redcar & cleveland
- 431
- 8
- Thanked 38 Times in 37 Posts
potterton puma 80
been call out to this boiler a few time now everytime i get there it works fine lady says it only seems to lockout first thing on a morning when its been off all night,, so going there in the morning before it fires up... has anyone had and dealing with a fault like this,,,,,
12-12-2011 #2UK Plumbersforums Trusted Advisor.
- Apr 2011
- Newcastle Upon tyne
- 6,115
- 306
Re: potterton puma 80
Sticking hot water micro switch is a common issue that causes these old birds to overheat fixter1 .... 1st thoughts
12-12-2011 #3Plumbers Arms member
- Oct 2010
- 1,654
- Thanked 81 Times in 81 Posts
remove the bottom panel and remove both screws of panel and drop panel down , the red neon will be on which means it is stuck in hot water mode , if you back the switch off and test with hot tap for making and breaking should sort it , good luck
12-12-2011 #4Plumbers Arms member
- Dec 2010
- 431
- 8
thanks lads i post back the outcome
potterton puma 80
By fixter1 in forum Central Heating ForumReplies: 3Last Post: 13-12-2011, 08:18 AM -
Potterton Puma 80
By daredevil1 in forum Plumbing ForumReplies: 5Last Post: 25-08-2011, 11:07 PM -
Potterton puma 80e
By Nas in forum Central Heating ForumReplies: 17Last Post: 12-05-2011, 09:36 PM -
potterton puma
By turnpin in forum Central Heating ForumReplies: 6Last Post: 28-12-2010, 05:15 PM -
potterton puma no ch
By gas man in forum Central Heating ForumReplies: 4Last Post: 16-12-2010, 06:30 PM
combimag
2 Hours Ago in Plumbing Tools
