Results 1 to 15 of 21
Plumbing & Plumbers Forum - BG AR missing screw from fire
Discuss BG AR missing screw from fire in the Gas Safe Register Forum - Public Forum at Plumbers Forums; Hi, going out to a job tomorrow. Old lady says BG have At Risked her Valor Fire as theres a screw missing. Her reply was, well its only BG who ...-
11-01-2011 #1Plumbers Arms member
- May 2010
- 186
- 29
- Thanked 6 Times in 4 Posts
Hi, going out to a job tomorrow. Old lady says BG have At Risked her Valor Fire as theres a screw missing. Her reply was, well its only BG who touch the fire so its your responsability.
Sounds about right to me.
Big question is, can anyone give any suggestions as to what screw missing could AR a fire, ive been trundeling throuch the MIs online but nothings shouting at me. Could be one i show the GS inspector when he comes out in a weeks time.
11-01-2011 #2uɐɯ sɐƃ moderator
- Jan 2010
- maesteg,south wales
- 13,341
- 827
- Thanked 1,266 Times in 1,209 Posts
Re: BG AR missing screw from fire
has it got a glass front?
GASMAN
The Following User Says Thank You to gas man For This Useful Post:
princegoose (11-01-2011)
11-01-2011 #3Plumbers Arms member
- May 2010
- 186
- 29
Hi, thanks for the reply, it doesnt have a glass front.
its a valor adorn
valor adorn - Google Search
guess ill find out when i get there with a selection of self tappers. im guessing its not on the gas side of things as they would have ID it??
11-01-2011 #4Steady Plumbing Forum Contributor
- May 2010
- Essex
- 141
- Thanked 36 Times in 30 Posts
screw head on restrictor elbow maybe
details of screws here http://www.valor.co.uk/valor/website...2722-02%29.pdfLast edited by hihowudoin; 11-01-2011 at 09:32 PM.
The Following User Says Thank You to hihowudoin For This Useful Post:
11-01-2011 #5uɐɯ sɐƃ moderator
- Jan 2010
- 13,341
- 827
know that fire well,could be burner locating screw,wire fixing kit screw or gas lever screw which i doubt its the later as fire would not work,dont forget to check aeration setting is correct this can get over looked,also this has a cast heavy facia screw missing from this could be perceived as ar but ott, this would be 2ba threaded 20 mm long
Last edited by gas man; 11-01-2011 at 09:36 PM. Reason: my eyesand brain have gone
GASMAN
11-01-2011 #6Plumbers Arms member
- May 2010
- 186
- 29
??? says in MIs aeration Non-adjustable.
hope i havent got wrong MIs, i hope she definitly has.
11-01-2011 #7
11-01-2011 #8uɐɯ sɐƃ moderator
- Jan 2010
- 13,341
- 827
could be a early one that used coals only,when BAXI took over the aeration setting was made adjustable for coals/pebbles
GASMAN
11-01-2011 #9Plumbers Arms member
- May 2010
- 186
- 29
11-01-2011 #10Plumbers Arms member
- May 2010
- 186
- 29
11-01-2011 #11uɐɯ sɐƃ moderator
- Jan 2010
- 13,341
- 827
no worries pg and thanks hihowudoin for the pdf the 940 is a shed prone to microswitch problems causing the lot to shut down,so be careful with the yellow wires
GASMAN
11-01-2011 #12uɐɯ sɐƃ moderator
- Jan 2010
- 13,341
- 827
have you got the gc can look on the arena for you
GASMAN
11-01-2011 #13Steady Plumbing Forum Contributor
- May 2010
- Essex
- 141
ahhhh found the br622 bit different gc 32 032 09
11-01-2011 #14uɐɯ sɐƃ moderator
- Jan 2010
- 13,341
- 827
does it have the aeration setting? or do i need to look at the arena?
GASMAN
11-01-2011 #15Steady Plumbing Forum Contributor
- May 2010
- Essex
- 141
no it didnt any adjustment show on arena , just one option of coals
The Following 2 Users Say Thank You to hihowudoin For This Useful Post:
gas man (11-01-2011),princegoose (11-01-2011)
Rhino Oil Combi Boiler - I'm missing a bolt!
By jamesmina in forum Plumbing ForumReplies: 6Last Post: 10-10-2010, 10:57 PM -
Missing Flue terminal?
By Bluey in forum Central Heating ForumReplies: 7Last Post: 22-08-2010, 11:30 PM -
Missing part of flue terminal
By Bluey in forum Gas Safe Register Forum - Public ForumReplies: 0Last Post: 22-08-2010, 05:41 PM -
amongst the missing
By turnpin in forum Plumbing ForumReplies: 3Last Post: 27-07-2010, 12:54 PM -
Missing service valve?
By The Trainee in forum Sanitary WareReplies: 13Last Post: 30-06-2010, 07:52 AM
Coating everything with silicone!!
23 Minutes Ago in Plumbing Forum
