Results 1 to 15 of 18
Plumbing & Plumbers Forum - comissioning a combi boiler
Discuss comissioning a combi boiler in the Gas Safe Register Forum - Public Forum at Plumbers Forums; Hi im a newly gas safe registered engineer but been a plumber for a few years. iv just installed my first combi boiler and i need to comission it and ...
    Jan 2011
    Question comissioning a combi boiler
    iv just installed my first combi boiler and i need to comission it and fill in the relevent paperwork. i know how to comission it but im not 100% sure can someone please help me and tell me the full procedure and paperwork details (cp12 and benchmark) and where i have to send the paperwork off to.
    i know its a bit of a silly question but i would really appreciate it as i feel i have a big responsibility to the my job correct for health and safety reasons.
    thanks!!
    CES
    CES is offline
    CES's Avatar
    Sep 2010
    Livingston
    2,270
    Default Re: comissioning a combi boiler
    You should install and commission as per the MI's. Fill in the benchmark details i.e., gas rate, co/co2 ratio, flow and return temps etc., instruct the customer in the safe operation and notify the boiler installation accordingly. Leave the paperwork for the customer, filling in all your details so there is a record that you installed and commissioned the boiler as per MI's. You don't need to send any paperwork away if you notify the boiler install online through gas safe website. Hope this helps a little.
  3. The Following 2 Users Say Thank You to CES For This Useful Post:
    mskh4n (09-01-2011),psk (13-01-2011)
    Jan 2011
    Quote Originally Posted by CES View Post
    wicked thanks alot very informative.i keep hearing from people you have to like send paperwork off but like what youve just told me iv heard you can do it online via the gas safe website which im a member of. how do i check the flow and return temps??i have a FGA but what tool would i need for recording the temps?just a normal thermometer? thanks again
    CES
    CES is offline
    CES's Avatar
    Sep 2010
    Livingston
    2,270
    If your FGA has temperature clamps, measure the temp on the flow and return using them, otherwise get a digital thermometer and a set of pipe clamps for it. Don't try using a laser thermometer as you cant get an accurate enough reading.
    Norfolk
    1,238
    No question is silly. You have to register the boiler for Building Regs part L Compliance. You can do this through Gas Safe Register or other approved Competent person schemes(CPS). As previously mentioned Commision boiler in accordance with MI's and instruct customer about its use.
    tamz's Avatar
    Scotland
    9,348
    And fill out the warranty card as some manu's will not honour the guarantee without it being registered.
  8. The Following User Says Thank You to tamz For This Useful Post:
    Reg Man (10-01-2011)
  9. #7
    1,363
    Gas Safe will register some manufacturers warrantys for you when you register the boiler with them.
  10. #8
    Jun 2010
    698
    Inform customer re servicing as to validate the warranty to continue after year 1, if a 2 or 5 year warranty.
    Pop the date of installation in your dairy & ring them the month before, most customers love this standard of care, you'll have a good customer for life.
  11. #9
    Jan 2011
    cheers guys! i have to commission it today hope it goes oright. thanks again you guys help me out alot
  12. #10
    GQuigley67's Avatar
    Oct 2010
    Glasgow, Scotland
    4,696
    does the relevant paperwork come with the boiler or do you need to get it seperately from a supplier ?
  13. #11
    CES
    CES is offline
    CES's Avatar
    Sep 2010
    Livingston
    2,270
    Benchmark sheet is usually printed in the servicing book, warranty card and guarantee comes with boiler.
  14. The Following User Says Thank You to CES For This Useful Post:
    GQuigley67 (12-01-2011)
  15. #12
    Jan 2011
    i too am newly registered with gas safe and I'm commissioning my first combi early next week.
    i have a bit of doubt in my mind as to the testing of the flow/return temps for CH. Am i right in thinking I can record the temps at any stage of the heating being on (i.e. as soon as the boiler is fired up even if system is ambient temp, or does the boiler need to be on for a certain amount of time)
    my guess is that i'm just recording the rise in temperature so doesn't matter what the return temp is.
    i'd be grateful if someone could confirm this.
    Thanks.
  16. #13
    Dannypipe's Avatar
    Apr 2009
    Tunbridge Wells
    5,133
    Let the system heat up properly and then check it. It's more the difference between the flow and return temps they're interested in. I.e how much heat is being used around the system.
    Gas, LPG, and OFTEC (oil) Registered.... visit my website at: www.prestigeplumbers.co.uk
    Click to follow the link!
  17. The Following User Says Thank You to Dannypipe For This Useful Post:
    heatingandgas (27-01-2011)
  18. #14
    Apr 2009
    415
    When I see posts like this is really does makeme wonder the the F*** is going on with our trade/industry these days
  19. The Following User Says Thank You to Plucky For This Useful Post:
    heatingandgas (28-01-2011)
  20. #15
    tamz's Avatar
    Scotland
    9,348
    Quote Originally Posted by Plucky View Post
    Don't it just
  1. combi boiler
    By Discreet-Heat in forum Central Heating Forum
    Last Post: 29-12-2010, 11:57 PM
  2. Best combi boiler to go for?
    By Lag1rich in forum Central Heating Forum
    Last Post: 21-12-2010, 06:09 PM
  3. Combi boiler
    By Dolala_1 in forum Central Heating Forum
    Last Post: 14-04-2010, 07:39 PM
  4. New combi boiler
    By steve2010 in forum Central Heating Forum
    Last Post: 29-01-2010, 11:50 PM
  5. Combi boiler
    By smithykins in forum Plumbing Forum
    Last Post: 08-12-2008, 07:47 PM
how to commision a boiler
how to commision a combi boiler
commision a boiler commision boilerwhy do you have to commision a boilerhow long to commision a boiler commissioning a combi boiler
