Results 1 to 12 of 12
Plumbing & Plumbers Forum - 3 pipe shuffle
3 pipe shuffle
Discuss 3 pipe shuffle in the Gas Safe Register Forum - Public Forum at Plumbers Forums; How would you run 3 pipes horizontal above a concrete kitchen floor ie at skirting bd level. Would it be gas bottom hot next and then cold just flirting with ...-
08-01-2011 #1Plumbing Forum Contributor
- May 2009
- 47
- Thanked 2 Times in 2 Posts
3 pipe shuffle
just flirting with the young ha
08-01-2011 #2Plumbers Arms member
- Sep 2008
- Plymouth
- 504
- 3
- Thanked 10 Times in 10 Posts
Re: 3 pipe shuffle
Hot above the cold to reduce condensation to cold pipe, gas however best for you.
08-01-2011 #3Plumbers Arms member
- Jul 2010
- Horsham, West Sussex.
- 2,080
- Thanked 165 Times in 165 Posts
I'd run hot at top and gas at bottom. That way you shouldn't get condensation on them.
08-01-2011 #4Moderator
- Nov 2007
- hythe hampshire
- 9,099
- 479
- Thanked 761 Times in 741 Posts
Re: 3 pipe shuffle
hot at top otherwise you will get warm cold water as well as condensation.
08-01-2011 #5Plumbing Forum Contributor
- May 2009
- 47
Re: 3 pipe shuffle
effect on tightness test?
08-01-2011 #6
08-01-2011 #7Top Plumbing Forum Contributor
- Sep 2010
- Cardiff
- 492
- 19
- Thanked 53 Times in 53 Posts
Re: 3 pipe shuffle
I think he means that a hot pipe would have an effect on the gas service if hot was below it.
My input here, would be that hot must be on top, followed by gas then cold.
The reason for this is mainly a legionella risk
08-01-2011 #8Plumbing Forum Contributor
- May 2009
- 47
Re: 3 pipe shuffle
ok you are all correct ha. But i did wonder years ago about temp stabilization and how it affects everything in readings. I think the biggest thing i learned is how a exposed gas pipe can fluctuate manometer readings. We all think it will read the same but it wont
08-01-2011 #9Moderator
- Nov 2007
- hythe hampshire
- 9,099
- 479
Re: 3 pipe shuffle
glad about that, we're doing something right then!
08-01-2011 #10UK Plumbersforums Trusted Advisor.
- Apr 2008
- South Shropshire
- 6,082
- 514
- Thanked 679 Times in 613 Posts
Re: 3 pipe shuffle
I'm sure you all know this, but to add my tuppeny worth ... water regs like hot above cold (protection against legionella, blah, blah).
Wish I'd read that post above before I spent ages typing this ...
08-01-2011 #11Plumbing Forum Contributor
- May 2009
- 47
Re: 3 pipe shuffle
only one with the answer!
08-01-2011 #12Plumbing Forum Contributor
- May 2009
- 47
Re: 3 pipe shuffle
from bottom to top gas cold hot the only way. Ducted pipe work ! you will see the results
can you run condensate pipe to a waste pipe inside the house ?
By northstar in forum Central Heating ForumReplies: 26Last Post: 27-02-2012, 05:12 PM -
TRV pipe cold. Return pipe hot. Rad hot at top, cool at bottom.
By rhubarbe in forum Central Heating ForumReplies: 33Last Post: 13-12-2010, 12:45 AM -
Condensate Pipe into Waste Pipe
By ceedy in forum Central Heating ForumReplies: 13Last Post: 15-08-2010, 02:02 PM -
Lead pipe from toilet to soil pipe.
By easyt in forum Plumbing ForumReplies: 1Last Post: 03-08-2010, 09:43 AM -
Cold water pipe branching from main pipe
By Southgate30 in forum Plumbing ForumReplies: 6Last Post: 12-06-2009, 10:42 PM
Really remote heating controls -...
12 Minutes Ago in Central Heating Forum
