Results 1 to 15 of 30
Plumbing & Plumbers Forum - Boiler Servicing Tools
Discuss Boiler Servicing Tools in the Gas Safe Register Forum - Public Forum at Plumbers Forums; I've got myself some brushes for cleaning out heat exchangers etc. But what I'm after are the thin solid metal tools (a bit like those metal thickness gauges but longer) ...-
08-01-2011 #1
I've got myself some brushes for cleaning out heat exchangers etc. But what I'm after are the thin solid metal tools (a bit like those metal thickness gauges but longer) to poke down the tight gaps of heat exchangers in ideal icos' etc.
Any ideas where I can get these from?
08-01-2011 #2uɐɯ sɐƃ moderator
- Jan 2010
- maesteg,south wales
- 13,350
- 828
Re: Boiler Servicing Tools
regin make them pts or parts centre
GASMAN
08-01-2011 #3Plumbers Arms member
- Jun 2010
- 698
- 11
- Thanked 107 Times in 106 Posts
If you're stuck a blunt hacksaw blade will do , but go easy.
08-01-2011 #4
08-01-2011 #5Top Plumbing Forum Contributor
- Sep 2010
- Cardiff
- 492
- 19
- Thanked 53 Times in 53 Posts
Not a good sign when aluminium exchanger blocked. Be gentle with the fins.
Probably green and grey. After i have cleaned one of these, my face burns?
Now, before i do this type of work, i throw a dust sheet over the flue.
With regards to brushes, when you buy a set, there will be a blade in there.Last edited by tipintim; 08-01-2011 at 03:55 PM. Reason: poor english, sorry
08-01-2011 #6uɐɯ sɐƃ moderator
- Jan 2010
- 13,350
- 828
REGT75 - Long Cleaning Blade | Regin
there you goGASMAN
The Following User Says Thank You to gas man For This Useful Post:
GQuigley67 (08-01-2011)
08-01-2011 #7
The Following User Says Thank You to willing2learn For This Useful Post:
gas man (08-01-2011)
08-01-2011 #8UK Plumbersforums Trusted Advisor.
- Oct 2010
- Glasgow, Scotland
- 4,696
- 324
- Thanked 260 Times in 254 Posts
that regin site looks like a handy site for equipment !
question, can you order off of this site ? can't see any prices anywhereLast edited by GQuigley67; 08-01-2011 at 05:17 PM.
08-01-2011 #9uɐɯ sɐƃ moderator
- Jan 2010
- 13,350
- 828
dont think you can but what ever you are after take down the part numbers and order it in pts,parts centre etc
GASMAN
08-01-2011 #10Plumbers Arms member
- May 2008
- 700
- 33
- Thanked 66 Times in 60 Posts
08-01-2011 #11
08-01-2011 #12UK Plumbersforums Trusted Advisor.
- Apr 2010
- Scotland
- 9,384
- 281
- Thanked 1,180 Times in 1,047 Posts
Best to wear a dust mask when doing these as the dust / powder that comes off is definitely not good for the lungs.
If i breath it in it near chokes me and it makes me itch too.
Use some air duster on it too or if you have none blow through it with the hose off your guage (that is when you get a lung full).
08-01-2011 #13uɐɯ sɐƃ moderator
- Jan 2010
- 13,350
- 828
GASMAN
tamz (08-01-2011)
27-08-2012 #14Plumbers Arms member
- Jul 2011
- Scotland
- 90
- 20
- Thanked 3 Times in 3 Posts
just to bring this back to life and save posting another thread about the same, I was wondering if anyone can recommend a good quality brush set , need to get my first set for servicing ? i found a couple of 9 and 11 piece sets on ebay, i wondered if any of you guys thought these looked decent enough quality wise, or if there is preferred brand used amongst the more experienced H/E's..?
cheers
27-08-2012 #15Plumbers Arms member
- Jan 2012
- Essex
- 3,201
- 80
Buy what you fancy, my latest set has 9 pieces and was on special at £5.50.
I know it will last at least a couple of years, good value or what?Proud to be 'Part P', the world is now my mollusc!
Boiler Servicing
By OFTEC in forum Plumbing ForumReplies: 36Last Post: 07-05-2011, 05:54 PM -
Oil boiler servicing advertisiing ideas
By mark_mc in forum Plumbing ForumReplies: 9Last Post: 06-01-2011, 12:20 PM -
condensing boiler servicing
By derrybongo in forum Central Heating ForumReplies: 14Last Post: 29-09-2010, 08:36 AM -
Boiler Servicing Question
By Malki in forum Central Heating ForumReplies: 4Last Post: 11-12-2009, 07:33 PM -
Boiler servicing courses
By lenny25 in forum Plumbing CoursesReplies: 0Last Post: 12-01-2009, 06:44 PM
3Likes
price guides
2 Hours Ago in Plumbing Forum
