Results 1 to 15 of 22
Plumbing & Plumbers Forum - anaconda
anaconda
Discuss anaconda in the Gas Safe Register Forum - Public Forum at Plumbers Forums; went to a job today were they meter was fairly new, all fixed in with the anti tamper bracket ecv side fine but other side coming of the meter to ...
    north west
    437
    Default anaconda
    went to a job today were they meter was fairly new, all fixed in with the anti tamper bracket ecv side fine but other side coming of the meter to pipework was anaconda pipe or meter pipe i thought that wasnt allowed but been done by transco or meter people so what do ye do replace it to cover yourself or leave it as been done by them,gunner ring gas safe to check tomoz
    Sep 2010
    Cardiff
    492
    Default Re: anaconda
    In my reg book it shows ridged pipework to be fitted off the meter. Is anaconda (flexi) feeding the meter.
    I have never seen flexable pipe on out let. Always meter union to 22.
    Also, only one pliable connector per installation is permitted.
  3. The Following User Says Thank You to tipintim For This Useful Post:
    metaldust9 (03-01-2011)
    1,366
    You arent allowed to use them on the outlet as installation pipework should be rigid (with the odd exception). Its not uncommon for people just doing meter swaps to use two annacondas to make their life easier.
  5. The Following User Says Thank You to mfgs For This Useful Post:
  6. #4
    north west
    437
    yep my thinking to,only reason ive posted this cos of meter already in,an wondering if i have to swap it
  7. #5
    233
    I thought it was only "illegal" if there were 2 anaconda's, more for "tampering tamperers" than safety, although not having a rigid on one side clearly isnt as secure.
    Intended installation is on transco side but i would think ncs
  8. #6
    north west
    437
    it is rigid because of tamper plate,but i would normally just swap it, my only issue is because it was already done by the meter installer who ever they are,therefore my thinking ,if not allowed they wouldnt be allowed to do it either
    also i no its not allowed anywere on pipework,but this is coming off the meter
  9. #7
    Sep 2010
    Cardiff
    492
    I would report it to supplier and cover your self by writting out warning -
    Not To Current Standards. Dont see why you have to change it foc.
    If they say its ok, post back here plz. Would be good to know.
  10. The Following User Says Thank You to tipintim For This Useful Post:
  11. #8
    kirkgas's Avatar
    Dec 2009
    Coatbridge, Lanarkshire
    3,515
    Quote Originally Posted by metaldust9 View Post
    as long as you write it down somewhere to cover you, it must only be NCS if the meter and other pipework is secure, could be AR if the connection to the copper is secured by clips and is likely to move and cause a leak, and advise the customer to contact the supplier, who should change it FOC, rather than you billing the customer for it,
  12. The Following User Says Thank You to kirkgas For This Useful Post:
  13. #9
    1,366
    I'm pretty sure its only NCS. I doubt the gas supplier would alter it FOC as its on the customers side of the meter.
  14. #10
    SafeGasInstall's Avatar
    Oct 2010
    Northampton
    6,058
    have seen many like this ,if I did any work to the gas pipe then I always did upgrade it ! but if is just safety check on appliance i just NTC it! you do not have to upgrade it(but if you can charge then take your time) and make sure earth bonding within 600mm or the first T.
  15. #11
    Steady Plumbing Forum Contributor hihowudoin's Avatar
    May 2010
    Essex
    141
    TB084 22/09/10 states "The requirements of Gas Industry Unsafe Situations Procedure(GIUSP)
    Where an existing meter installation is encountered with two pliable connections fitted, the installation should be classified as "Not to Current Standards" (NCS) in accordance with the procedure detailed in the current GIUSP (TB001). The Gas user/responsible person should be advised to contact their gas supplier in order to rectify the matter."
  16. The Following User Says Thank You to hihowudoin For This Useful Post:
    metaldust9 (04-01-2011)
  17. #12
    north west
    437
    thanx everyone ,like av said ,anywere else it wouldnt even be a discusion or issue,ive asked the question only because of were it is and who,s fitted it
  18. #13
    east london
    6,666
    i was told one per meter either side
  19. #14
    uɐɯ sɐƃ moderator
    gas man's Avatar
    maesteg,south wales
    13,347
    yes one as far as i was aware as well
    GASMAN
    IMPOR
  20. #15
    north west
    437
    yep gas man an ste the plumber one each meter, rung gas safe tho an checked it comes under NCS if am working on that piece of pipework and have to remove it then i have to change it,if not changing that section then can stay as it is and advise customer to ring transco or there gas supplier to get it changed
  1. Replies: 3
    Last Post: 26-11-2010, 07:56 PM
anaconda gas pipe
gas pipe anacondagas anaconda pipewhy did gas man change anaconda meter pipe when changing cooker pipeanaconda gas pipe rightgas installation anacondasanaconda gas pipe leak
