Plumbing & Plumbers Forum - BS 6896 Radiant tube heaters
Discuss BS 6896 Radiant tube heaters in the Gas Safe Register Forum - Public Forum at Plumbers Forums; Don't suppose any of you good people know where i can obtain a copy of BS6896? ideally for free but don't mind a reasonable cost. I refuse to pay the ...-
09-12-2010 #1Plumbing Forum Contributor
- Feb 2010
- 36
ideally for free but don't mind a reasonable cost. I refuse to pay the extortionate figures iv'e been quoted. Personally find it offensive what they charge for BS and IGE documents. No wonder there are so many iffy installs out there, should all be free to RGI's.
TIA
Al
10-12-2010 #2
Re: BS 6896 Radiant tube heaters
Try your local library. Mine has access to the Standards and I can also access them via the web. Mind, some library memberships allow you to print and some do not.
The Following User Says Thank You to CMairiD For This Useful Post:
alspeed (10-12-2010)
10-12-2010 #3Plumbing Forum Contributor
- Feb 2010
- 36
Thanks will give them a try, must admit it's not a scource I had considered, tend to forget libraries exist, too reliant on google these days!
10-12-2010 #4UK Plumbersforums Trusted Advisor.
- Dec 2009
- Coatbridge, Lanarkshire
- 3,515
- 52
- Thanked 342 Times in 315 Posts
can i ask if you intend to use it for personal use, or would you be likely to circulate it to others, they are covered by copyright so it isnt ideal to start circulating a copy that is marked (
) send me a PM as i would like to discuss another matter with you
12-12-2010 #5Plumbing Forum Contributor
- Feb 2010
- 36
Kirkgas
You have PM!
plinth heaters
By wnjswozo in forum Central Heating ForumReplies: 7Last Post: 17-11-2010, 10:27 PM -
Plinth Heaters
By loughtonlion in forum Central Heating ForumReplies: 1Last Post: 26-02-2010, 03:23 PM -
installing a programmable room stat to a radiant sirrus boiler
By moogwai in forum Central Heating ForumReplies: 5Last Post: 24-01-2010, 04:06 PM -
Usage of non-barrier PEX in section of radiant underfloor heating system
By plumb-paddy in forum Plumbing ForumReplies: 1Last Post: 06-09-2009, 07:18 AM -
water heaters ....
By tomplumb in forum Plumbing ForumReplies: 11Last Post: 13-03-2009, 04:12 PM
Keep back boiler or get combi
1 Minute Ago in Central Heating Forum
