Results 1 to 4 of 4
Plumbing & Plumbers Forum - Baxi Solo 2 Over heating....
Discuss Baxi Solo 2 Over heating.... in the Gas Safe Register Forum - Public Forum at Plumbers Forums; Hi, I'm looking for a little bit of advice regarding a boiler overheating problem. Currently my Baxi Solo boiler will run successfully for about 24 hours before locking out with ...
    Sep 2010
    Default Baxi Solo 2 Over heating....
    Currently my Baxi Solo boiler will run successfully for about 24 hours before locking out with the overheat light on.
    General observations: I have noticed that when the room thermostat is at the correct temperature, the boiler cuts out as normal, however (not every time) when it starts to cool down there seems to be excessive water noise coming from the outlet?! pipe to the boiler, it is at this point the overheat light only comes on.
    The usual switch the boiler thermostat off for 10 sec's doesn't reset the lockout. However if I increase the room thermostat so that the pump kicks in the boiler on light comes on and i'm able to reset. The boiler will then work ok for another 24 hours.
    The pump has been replaced and the system drained down to replace by a professional (this was done in june as the original pump was not working correctly and caused airlocks within the system) Obviously i've only just started to run the CH more which has seen the problem increase.
    Help and Advice gratefully received.
    Simon
    Jun 2010
    698
    Default Re: Baxi Solo 2 Over heating....
    Sounds like pump overrun board.
    Needs to be checked out electrically by a G S repair eng.
    Aug 2010
    belfast
    166
    Quote Originally Posted by aggis View Post
    +1 on this, when you turn your room stat down your pump should continue to run, try this and if it doent might be a fault on the pcb or just not wired correctly
    Sep 2010
    Ahh ok thanks for that one chap, excuse my idiot question, from a parts perspective that's the OverHeat Thermostat and the OverHeat sensor that may be at fault?
    Diesel_Ltd - The pump does seem to run for a few mins when the room stat temp is at the correct temp.
    Btw, thanks for the replies chaps
  1. Newbie with Baxi Solo 2 problem
    By onyourbike in forum Central Heating Forum
    Last Post: 19-04-2012, 12:20 PM
  2. Baxi SOLO HE problem
    By Tommy Bow in forum Central Heating Forum
    Last Post: 02-11-2010, 09:52 PM
  3. Replacing Baxi Solo 3 60 PFL with what?
    By Derekmac in forum Central Heating Forum
    Last Post: 18-09-2010, 05:49 PM
  4. Boiler Noise - Baxi Solo
    By Penworth in forum Gas Safe Register Forum - Public Forum
    Last Post: 11-09-2010, 07:26 PM
  5. Water leak on Baxi Solo 2
    By pezza37 in forum Central Heating Forum
    Last Post: 27-12-2009, 03:31 PM
baxi boiler overheat light
baxi boiler overheating
baxi solo 2 overheat reset
baxi solo 2 overheat problem
baxi boiler overheating light
baxi solo 2 overheating
