Results 1 to 12 of 12
Plumbing & Plumbers Forum - A BIG ask!!!!
A BIG ask!!!!
Discuss A BIG ask!!!! in the Gas Safe Register Forum - Public Forum at Plumbers Forums; Just had a phonecall from a fella asking me if i could sign off a multi point water heater and i asked the question as to who installed it and ...-
13-07-2010 #1Plumbing Forum Contributor
- Jul 2008
- In your mind
- 94
- Thanked 1 Time in 1 Post
A BIG ask!!!!
water heater and i asked the question as to who installed it and he said a
plumber installed the appliance and then i asked if he was gas safe registered
and he said NO so i said instantly that i am not prepared to sign off any work that was installed by a plumber.
Why he did not get a gas engineer to install the heater is beyond me as he has now shot himself in the foot as its gonna cost him loads to get the boiler de-commissioned and re-commisioned by a gas safe engineer
Not risking my ticket for the sake of 100 quid which is what he wanted to pay..the cheek.
Has anyone else beem asked to sign of work that was not installed by a gas safe engineer as i would like to know what their outcome was
13-07-2010 #2Banned
- Dec 2009
- Portsmouth
- 672
- 64
- Thanked 70 Times in 68 Posts
Re: A BIG ask!!!!
I have been asked loads of times, to which my answer is always no.
Not worth risking it.
Graham
13-07-2010 #3Steady Plumbing Forum Contributor
- Jun 2010
- 110
- Thanked 7 Times in 7 Posts
Re: A BIG ask!!!!
same here, i have been asked lots of times. its not worth the risk or hassle to do it.
i do enjoy telling them they have voided there warrenty tho
13-07-2010 #4Moderator
- Jul 2009
- Staffordshire
- 2,548
- 41
- Thanked 191 Times in 162 Posts
Re: A BIG ask!!!!
you can bet that they will reach someone who will do it tho
Regards
Tom
13-07-2010 #5Plumbers Arms member
- Jun 2009
- 753
- Thanked 22 Times in 22 Posts
Re: A BIG ask!!!!
dont do it ,not worth it
13-07-2010 #6UK Plumbersforums Trusted Advisor.
- Dec 2009
- Coatbridge, Lanarkshire
- 3,515
- 52
- Thanked 341 Times in 314 Posts
Re: A BIG ask!!!!
who is worse? the non RGI who fitted it or some bam who is registered who signs it off for some cash? (can you tell who i think is worse?????)
13-07-2010 #7Top Plumbing Forum Contributor
- May 2010
- Near Chester
- 573
- 5
- Thanked 24 Times in 24 Posts
Re: A BIG ask!!!!
As a layman in these matters- would it be OK to ask a qualified person to disconnect the gas and recommission ?
13-07-2010 #8Plumbers Arms member
- May 2009
- 7,303
- 218
Re: A BIG ask!!!!
The manufacturers and government,for letting appliances be sold to non registered people,for a bit of extra cash,I like the TV license system,purchasers have to fill in their name and address and if appliance not registered within a month,letter sent out and maybe a fixed fine,every month,increasing until registered,after four months and not registered,gas disconnected and their finger nails pulled out one at a time,if you are not going to do above and enforce regs,why bother
The issue is having appliances fitted correctly and safely not who does and does not sign them off,that should not be a issue
imhoLast edited by Puddle; 13-07-2010 at 11:01 PM.
13-07-2010 #9Top Plumbing Forum Contributor
- Apr 2010
- 838
- Thanked 33 Times in 32 Posts
Re: A BIG ask!!!!
Why didn't u say that u would go commision the appliance but charge extra as u would have to double check everything as it wasn't u that fitted it. Worse case scenario is u ID it and then charge for the rework. If it's not fitted to standard again just charge for rework or u won't sign it off, put the ball in his court. Seems win win to me tbh
13-07-2010 #10Super Plumbing Forum Contributor
- Feb 2009
- Liverpool
- 1,972
Re: A BIG ask!!!!
Should have a scheme where the local council come out and inspect and test for a set fee.
Like they do for electrical installations.
16-07-2010 #11Plumbers Arms member
- Jun 2010
- The South
- 636
- 18
- Thanked 61 Times in 61 Posts
Re: A BIG ask!!!!
Just make all necessary checks, pay particular attention to gas, flue, ventilation etc, charge extra for the hassle. Job done, nice bit of cash
16-07-2010 #12Banned
- Jul 2009
- North Devon
- 1,889
- 5
- Thanked 86 Times in 76 Posts
Re: A BIG ask!!!!
dont forget to rip up the floor to replace the gas supply to ensure you are happy it meets the standards required, have a look at the gas safe tech note on doing this work and you probably wont ever consider signing off someone elses work, unless you can reinstall from scratch.
repacling a bath that's too big so fitted into wall cavity
By kjw in forum Sanitary WareReplies: 13Last Post: 29-07-2010, 04:00 PM -
ContractorForum: Wetdecs: Big thanks to Tony at Wetdecs I tried to get hold of him on
By Dan in forum Links, Forum Updates, News and Site SuggestionsReplies: 0Last Post: 18-12-2009, 08:30 PM -
Big problem!!!!
By Muscle750 in forum Plumbing ForumReplies: 13Last Post: 23-11-2009, 09:38 PM -
BIG Plumbing / Building & Plumbing Companies
By WaterTight in forum Plumbing ForumReplies: 0Last Post: 05-06-2009, 12:43 AM -
connecting 40mm waste to a big hole in the ground????
By obseen16 in forum Plumbing ForumReplies: 4Last Post: 21-08-2008, 11:31 AM
Freebie Alert - Black Mamba - the...
