Results 1 to 8 of 8
Plumbing & Plumbers Forum - New house move, two appliances one water source
Discuss New house move, two appliances one water source at UK Plumbers Forums; Hi, I have one water supply and i want to run two appliances, a dish washer and a washing machine. The parts i have been looking at using are. Compression ...
    Jan 2017
    Default New house move, two appliances one water source
    Compression appliance tee from screw fix and a twin waste adapter from amazon,
    Would i need anything else ?
    Any advice on getting the ball rolling would be great !,
    i will post before and after pictures also.
    Looking forward to your replies
    Curt
    Attached Thumbnails Attached Thumbnails New house move, two appliances one water source-img_2027.jpg
    jtsplumbing's Avatar
    Tavistock. Devon
    4,806
    Default Re: New house move, two appliances one water source
    Why not just get someone in to do it ? some of these so called simple jobs can turn into a nightmare,, the cold side is simple enough, but you may have a problem with the waste .
    Plumbstar Tom's Avatar
    Jul 2009
    Staffordshire
    3,669
    you will probably find that a compression appliance tee won't allow the further appliance to reach, same for the waste
    Ideally it needs to be done properly with an extend run of the copper and waste
    Regards
    Tom
    rpm
    rpm is offline
    Member rpm's Avatar
    Wherever I lay my hat
    7,959
    If I`m not mistaken you already have a T junction on that pipe, where does that pipe go to?
    Jan 2017
    The white waste pipe goes out to the drain outside, and the copper pipe comes from the cold supply, and gives to the washer and sink
    Jan 2017
    The appliances are next to each other, so i would not need to extend anything fortunately, i just need to give the water source two outputs
    Super Moderator
    steveb's Avatar
    Nov 2007
    hythe hampshire
    12,921
    this is what you need from toolstation
    http://www.toolstation.com/shop/Plum...e+Valve/p71693
    The Turtle Moves
    Jan 2017
    Thanks for all the help, its done now everything is working great
  1. Replies: 15
    Last Post: 2 Weeks Ago, 07:23 PM
  2. Ground source water map
    By Robert Tyrrell in forum Oil and Solid Fuel Forum
    Last Post: 04-12-2013, 09:40 AM
  3. How appliances deal with dirt in the water
    By jh72i in forum Valves & Taps
    Last Post: 26-02-2013, 04:58 PM
  4. Can plumbers move water meters?
    Last Post: 15-11-2011, 11:24 PM
