Results 1 to 4 of 4
Plumbing & Plumbers Forum - Pipe offset advice
Pipe offset advice
Discuss Pipe offset advice at UK Plumbers Forums; Hi, I'm installing a bathroom at the front of the house and need to get the main 110mm waste pipe to the back of the house where the main stack ...
    Dec 2016
    Default Pipe offset advice
    Hi, I'm installing a bathroom at the front of the house and need to get the main 110mm waste pipe to the back of the house where the main stack is.
    I've had to drill a large hole in the landing wall in order to get the pipe through to the other side, however directly on the other side of the hole is breeze block. I can extend the hole a bit to dodge this (as I don't want to cut the breeze block if possible) however it will require a bend in the waste pipe. Ideally I could just use an offset connection, however the only offsets I can find are for pan connectors. Do offset connections exist for just mid-pipe requirements? I can't find any. The alternative is putting in 2 bends (creating a shallow s bend) however this will take up quite a lot of space.
    Riley's Avatar
    Sarf Coast
    6,387
    Default Re: Pipe offset advice
    Use 2 x 45° ??
    And you do know a knew bathroom is notifiable don't you??
    Dec 2016
    Yes, thanks.
    1,996
  1. Replies: 0
    Last Post: 27-04-2016, 10:44 PM
  2. Carron swan offset, omega offset, Utopia Symmetry?
    By Smee in forum Bathrooms, Showers and Wetrooms
  3. Offset measurement.
    By mike-c in forum Plumbing Forum
    Last Post: 13-10-2012, 12:40 AM
  4. offset pan connector
    By Nat in forum Plumbing Forum
    Last Post: 21-11-2011, 12:10 AM
  5. Offset toilet waste connector (small offset)?
    By steverog in forum Plumbing Forum
    Last Post: 07-07-2009, 02:34 PM
