Plumbing & Plumbers Forum - Run open vented hot pipe to tundish/waste pipe??
  • 1 Post By snowhead
Discuss Run open vented hot pipe to tundish/waste pipe?? at UK Plumbers Forums; Hi all, My customer has had a legionella assessment done, as part of renting out her house. She has a fairly new, open-vented CWST in the attic. The hot water ...
    Sep 2011
    146
    Default Run open vented hot pipe to tundish/waste pipe??
    Hi all,
    She has a fairly new, open-vented CWST in the attic. The hot water vent pipe discharges over the CWST, as is standard practise. However, the assessor says this is a legionella risk, and has recommended the pipe be re-routed via a tundish to a suitable discharge point.
    Personally, I think the assessor is being overly thorough. I've never heard of the vent pipe being run in such a way.
    But maybe I'm missing something.
    Plus also the tank needs a clean. It has sediment on the bottom. It's loose, and easily wiped off (if I drained down). But would you recommend I do a thorough disinfection of the tank, and - in which case - what chemicals/method would you recommend.
    I'd be grateful for your thoughts on this.
    Thanks so much
    Jennie
    Attached Thumbnails Attached Thumbnails Run open vented hot pipe to tundish/waste pipe??-img_2500.jpg
    Chalked's Avatar
    3,922
    Default Re: Run open vented hot pipe to tundish/waste pipe??
    Blooming legionella assessments.
    They go on a day course, and know it all. If they went by the rules, we wouldn't be allowed any header tanks!
    Apparently,the worst place in any house for legionella is the spout of a tap. They have to note on a report of there is any scale build up.!
    Elf & safety!!!!
    2,029
    It standard practice in the Commercial buildings I work on to have Vent to drain not to tank.
    Stops the tank getting over 20 if there's any venting over.
    And all the spray tap spouts and heads are cleaned regularly.
    ShaunCorbs likes this.
  1. Open vented system,advised to cap off expansion pipe??
    By Fluke77 in forum Central Heating Forum
    Last Post: 01-11-2016, 07:55 PM
  2. expansion pipe on a open vented system
    By oldplumber john in forum Central Heating Forum
    Last Post: 05-08-2016, 11:20 PM
  3. open vented system , vent pipe discharging when heating turnd on
    By markmonty in forum Central Heating Forum
    Last Post: 21-08-2013, 08:17 PM
  4. Replies: 2
    Last Post: 20-08-2013, 08:01 PM
  5. Vent Pipe in Loft from Open Vented System
    By wildhorses in forum Central Heating Forum
    Last Post: 01-12-2012, 11:59 PM
