Plumbing & Plumbers Forum - connecting to outside main
Discuss connecting to outside main at UK Plumbers Forums; got to connect up to old steel pipe, it looks like 3/4 pipe to me. what is the best option to connect to? copper? plastic? any help would be great ...
    Member chelsea's Avatar
    Jul 2008
    In your mind
    126
    Default connecting to outside main
    its being buried too
    Mar 2013
    1,446
    Default Re: connecting to outside main
    Replace with MDPE , Confirm steel with magnet. Lead will scratch easily. If lead, use lead lock as coupling. If steel, best to find threaded coupling but take care when uncoupling not to unscrew any part of pipework you wish to retain.
    Jul 2008
    In your mind
    126
    its deffo steel, mdpe conects to the steel pipe? or do i need to get an iron to fit?
    Mar 2013
    1,446
    MDPE to BSP coupling. DZR with locktite 55 on threads.
    9,993
    If you can find a joint remove and use a male or female iron or cut pipe and use a philmac trans coupling
  1. dis connecting a gas cooker!
    By mooey in forum Plumbing Forum
    Last Post: 19-08-2015, 11:43 PM
  2. Connecting PEX to Copper?
    By PinkyPerky in forum Plumbing Forum
    Last Post: 11-02-2014, 12:18 AM
  3. Connecting 2 oil boilers
    By honestbob in forum Oil and Solid Fuel Forum
    Last Post: 17-07-2013, 09:45 AM
  4. Connecting hosepipe to outside tap
    By noconsistency in forum Valves & Taps
    Last Post: 28-03-2013, 05:37 PM
  5. connecting copper to galvanized incoming main?
    Last Post: 12-11-2011, 11:02 PM
