Results 1 to 8 of 8
Plumbing & Plumbers Forum - Capping off a soil pipe
Discuss Capping off a soil pipe at UK Plumbers Forums; What's the best way to seal and cap this soil pipe before I concrete over it? Inside diameter seems to be just over 100mm. It's seems to be ceramic. Regards, ...
    kc1
    kc1 is offline
    Sep 2012
    Default Capping off a soil pipe
    Regards,
    Kevin
    N.Ireland, United Kingdom
    7,109
    Default Re: Capping off a soil pipe
    It should be same internal size as new plastic soil pipes. You could use a standard 4" internal cap. It will have a ribbed rubber outer seal. Best get as heavy duty one as possible, but any will do.
    Mar 2013
    1,487
    Ram a cement bag or similar 4" down the pipe as a stopper and then plug it with concrete.
    7,109
    If you want to use a plastic bung, this is one type,
    https://www.plastics-express.co.uk/s...FeYK0wod4qcJLg
    2,047
    How far away from a manhole is it?
    It should be plugged as close as possible to the junction to avoid a nice dry home for rats.
    kc1
    kc1 is offline
    Sep 2012
    Probably about 4-5m from the manhole. I'm assuming that other things in the house use the same feed into the manhole - but I would need to check to be sure. There is a WC close to the soil pipe in the photo, so I assume these connect together somewhere.
    Mar 2013
    1,487
    Be aware, with old clay pipes joints are solid, sand/cement, and pipes are relatively fragile. Not unusual when breaking into pipe, for adjacent pipes to fracture. Unless there is space and inclination to excavate and relay broken pipes keep disturbance to minimum.
    Last Plumber's Avatar
    Aug 2016
    Lancashire
    1,585
    Cut a piece of slate to sit nicely in the collar and mix grit sand and cement 4:1, fill and level it
  1. Capping Off 63mm PVC pipe ?
    By Thats Ballcocks in forum Plumbing Forum
    Last Post: 22-04-2015, 11:29 AM
  2. Capping off a vent pipe
    By Bunker in forum Central Heating Forum
    Last Post: 02-05-2014, 10:57 PM
  3. External gas pipe capping solved...
    By plumber0808 in forum Gas Safe Register Forum - Public Forum
    Last Post: 18-07-2013, 07:07 PM
  4. Capping off old soil pipe
    By GBZ in forum Fittings & Pipes
    Last Post: 09-08-2011, 11:54 PM
