Results 1 to 9 of 9
Plumbing & Plumbers Forum - Replacing new bathroom advice
Discuss Replacing new bathroom advice at UK Plumbers Forums; Hello,We installed a new bathroom around 9 years ago and used the speedfit push fittings. Now replacing it again with a new suite that is going in exactly the same ...
    Oct 2016
    10
    Default Replacing new bathroom advice
    Now replacing it again with a new suite that is going in exactly the same position.
    Never had any problems with any of the fittings leaking so could :
    1. use the same fittings
    2. Just replace the inserts/washers
    Or should i just replace with new ones
    ta, k
    1Steven's Avatar
    Jun 2015
    Lincolnshire
    548
    Default Re: Replacing new bathroom advice
    Hello and welcome!
    Oct 2016
    10
    Quote Originally Posted by 1Steven View Post
    Hello and welcome!
    Thank you 1Steven
    Apr 2008
    West Yorkshire
    3,836
    Why wasn't it done properly in copper the first time? certainly don't mess around replacing all the seals, either leave or replace everything.
    JOTM winner September 2012
    Oct 2016
    10
    Quote Originally Posted by Phil View Post
    Hi Phil,
    Thanks for replying
    Is there problems using PEX barrier pipe as a plumbers ive spoken to also seem to now favour this over copper pipe?
    Im a diyer and have no solder experience.
    K
    10,020
    if you can and want to keep as you are replace the fitting that your taking off/ changing
    Apr 2008
    West Yorkshire
    3,836
    Its one thing to use it under the floor downstairs but in bathrooms failures are costly as everything is normally tiled over.
    Plumbers only like it as its quick to use, everything else about it is rubbish.
    Jan 2014
    447
    am a copper man but if you wish to us plastic and push fit,do not reuse old fittings and do not place fittings under the floor...loop plastic from bath to basin and then wc,using fittings under bath and basin...and use ball-a-fix valves with handle,so can be isolated easily and quickly by anyone if need be..hope refit goes well..
    Oct 2016
    10
    Cheers guys for your input. Thats the reason i love browsing these forums so that i get loads of different opinions and advice from professionals.
    All of the fittings will be accessible and will be fitting isolation valves
  1. Replacing bathroom rad with Towel Rad
    By Alex Boothby in forum Plumbing Forum
    Last Post: 15-02-2016, 06:54 PM
  2. Replies: 1
    Last Post: 22-03-2015, 09:59 PM
  3. Advice about replacing an electric shower
    By fieldsl in forum Bathrooms, Showers and Wetrooms
    Last Post: 03-09-2013, 11:10 PM
  4. replacing a combi boiler - need a bit of advice please
    By emz in forum Central Heating Forum
    Last Post: 27-02-2013, 05:37 PM
  5. Problems after replacing bathroom suite
    By ianmwxm in forum Plumbing Forum
    Last Post: 31-08-2010, 08:44 PM
